Author Topic: Inital Power Spike IC-7300  (Read 8636 times)
VR2AX
« Reply #15 on: May 22, 2017, 03:58:58 AM »
I wonder how Icom achieve the 50 watt limit in your Japanese version. I'm no expert on power spikes but it looks like a design issue combined maybe a marginal choice of amp for your driver.
Why did the suggest a bigger power supply?
AC2RY
« Reply #16 on: May 22, 2017, 05:13:47 AM »
The RMA-305 will drive to full output with 10 watts input. What is your power output on the 7300 set at and limiting the maximum power to 10 watts is a bit harsh for the ALC on a 100 watt radio.
The radio is the 50W model. Depending on the band, I drive the amp with anything between 7% and 15%. Anything more than that will cause the amp to trigger the safe mode.
One suggestion I read in this thread, but have not tried yet, is to set some TX delay. I wonder if that may make some difference.
Luca
For SSB I suggest to play with mic gain and compression settings - reduce gain and increase compression. Microphone equalizer setting also may help - reduce bass down. Also you may think about placing microphone further away from the mouth. Generally you should barely see ALC indicator moving when you speaking, or not at all. Of cause your power supply should provide 20 amps without significant sag (below 0.5 volts).
KI7DUX
« Reply #17 on: May 22, 2017, 05:19:19 PM »
Your guess it as good as mine. But I think it is more related to not having a clue, not knowing how to fix the issue, but still not wanting to replace the radio. Or they are aware of the flow in the design, but rather than admit it they rather blame some other random part of the system.
The power supply is rated for 40 Ampere and it is dedicated just to the amp, the radio has its own. I really doubt that the power supply is really the issue.
Luca
AC6CV
« Reply #18 on: May 22, 2017, 07:10:48 PM »
I've used a 7300 with an Acom 1500 (since last Sept) through many contests, and haven't noticed any spikes that would affect the amp. I had two hot switch faults that I remedied by changing the TX Delay from 10 to 15ms. I drive the amp with 60-70% power from the 7300 (1,300W CW; 1,500W Peak SSB), and #2 compression on SSB...no problem. I also use two Heil dynamic mics, with audio gain control at 65-70%. If I use VOX, the VOX gain has to be around 90% for proper activation.
73, Bob K7JQ
I agree. Many amateurs are unaware of the delay or don't use it for what ever reason and have problems. Icom has an adjustable delay. Kenwood, if I recall, just has a 20ms on or off delay. I set my 7300 and 7600 delay at 20 ms and have never had any problems.
WA1RNE
« Reply #19 on: May 24, 2017, 09:21:18 AM »
have this problem too. On SSB, occasionally, my amp goes in fault mode on keying down the PTT.
I prepared a video to show the overshoot measured with an Ameritron AWM-30B, that is supposed to show peak readings. The overshoot was clearly visible.
 Have you monitored just the IC7300 driving a dummy load with the same wattmeter at 10 watts, 15 watts and 100 watts?
 Here's a couple of observations and suggestions:
 - the RM Italy manual states the amplifier requires 45 amperes maximum at 13 vdc as opposed to 40 amperes.
-  the schematic shows the amp uses a peak power detector at the input and is supposed to automatically insert an attenuator pad at the input if you exceed 10 watts. If you exceed 15 watts the amp goes into protection mode and shuts down. So not including tolerances, you have a 10-15 watt window to work within before the amp shuts down.
 If no output overshoot is noticed after running the above peak power tests on just the 7300, the wattmeter may not be fast enough to see it.  An 8-10 dB pad at the input of the amplifier might be what you need at that point.
  ...WA1RNE
KI7DUX
« Reply #20 on: May 24, 2017, 06:17:06 PM »
Yes that is more or less what I did, apart the fact that the radio is the 50W version.
Here is the video: https://youtu.be/tBtiEeWFuvU
One thing that I completely forgot is that in the video the overshooting only happens with compression engaged. Is this expected?
Luca
WA1RNE
« Reply #21 on: May 26, 2017, 07:20:25 AM »
 Sorry, I meant 50 watts not 100, forgot you have the Japanese version of the radio.
 There is really only one way to get to the bottom of this:  you need to monitor the transmitter output at the dummy load with a digital storage oscilloscope.
 This will allow you to positively confirm output overshoot and will also provide some verification of the wattmeter dynamics.
 ...WA1RNE
W3RSW
« Reply #22 on: May 26, 2017, 05:57:10 PM »
My LP1-100A seems to latch on the biggest pep spike or signal it sees and holds on to that until the transmission drops to zero and next signal starts.  Grin. I run into this action mostly on AM where there's a constant carrier with varying overriding sidebands yielding PEP.
As others have mentioned The scope's the ticket for the last word, even an old Navy OS8 with the signal tied directly to the CRT plates via well endowed rear panel connectors. Shows everything when the shack lights are dim for that old green trace.  Don't blink.  Grin
Rick, W3RSW
VK3BL
« Reply #23 on: June 03, 2017, 03:54:22 AM »
The IC-7300 does indeed have a power spike, although it is only minor in my experience.  Any amp suitable for use with 100 watts drive should be fine.
Worse case scenario, build a 50 Watt 3dB attenuator and run that in line with your amplifier.  Most SS radios produce their cleanest signals around the 70% drive mark anyway.
J.D. Mitchell BA  - VK3BL / XU7AGA - https://www.youtube.com/ratemyradio
M0VMT
« Reply #24 on: December 23, 2017, 06:05:15 AM »
 I had the same issue and contacted icom uk and was told to do more grounding to no avail I might add, I gave up on this radio as icom did not even want to check it over.
 I bought a yaesu after owning icom 12 years and guess what no spiking on my acom linear so I would say icom have issues with some batches but they are unwilling to admit it.
 This has put me off icom forever my 7600 never spiked my acom, well back to yaesu for me now.
AA2UK
« Reply #25 on: December 23, 2017, 10:11:16 AM »
It's classic Icom ALC overshoot. It will not impact most tube amplifiers.
It's pronounced when driving a low drive FET amplifier.
I have an Icom IC-7410 it doesn't care where the output is set to or the mode, it has a full power spike that happens in 0-50 milliseconds and is very short in duration (<10ms) more then enough to trip even damage many high gain FET amplifiers.
https://www.w8ji.com/alc_exciter_power_overshoot.htm
Bill, AA2UK
G4AON
« Reply #26 on: December 24, 2017, 01:28:45 AM »
Many transceivers produce initial power spikes when set to less than full output, it’s a major design fault that few care about. Even ARRL reviews don’t often include checks for it, yet the problem is easy to see on an oscilloscope, especially the newer digital scopes that hold the display of a single CW “dit”.
Elecraft are one of the few manufacturers that take care to avoid these problems, but many American hams would rather buy Japanese for some odd reason.
73 Dave
« Reply #27 on: December 24, 2017, 04:49:18 AM »
For many years, manufacturers have relied on ALC to set power levels. That means that with conventional ALC systems, there will be a degree of overshoot until the ALC operates: the time of the overshoot will be dependent on ALC time constants, and the magnitude will be dependent on the drive level set and the PA gain compression point. My old FT102 is bad for this, especially if the speech compressor isn't used because then output power  is fixed by the ALC - and the Acom 1500 amplifier trips out as a result.
« Reply #28 on: December 24, 2017, 05:15:17 AM »
I am always surprised that manufacturers haven't adopted a feedforward control loop topology. But since the new generation of radios are software defined, fixing such issues is only a matter of a software update. Time will tell if the manufacturers are responsive to this type of issue.
K0CWO
« Reply #29 on: December 24, 2017, 03:52:37 PM »
I’ve owned the IC-7300 for over a year. I have not observed power spikes with it at any power level or mode.  It has been driving an Acom 600S without issues to 600 watts SSB PEP.  I recently acquired an SPE 1.3K-FA and it puts out 1200 watts SSB PEP without issues as well.  Both amps are driven at 15-20 watts for rated output.  I wonder why some radios have this power spike and some don’t?  If it can be fixed by a software update, I wonder why Icom hasn’t done that yet?
Merry Christmas, k0cwo
