Author Topic: Technician and JT-65  (Read 1983 times)
KA1OWC
« on: June 20, 2017, 12:02:55 PM »
Haven't been able to get a straight answer on several forums! Is it permissible for Tech Class amateurs to operate on any or all of the JT-65/JT-9 frequencies? Thanks a lot...
Steve KA1OWC
Steve, KA1OWC
Retired Lieutenant Colonel, US Army
Army Nurse Corps
« Reply #1 on: June 20, 2017, 12:16:26 PM »
Only on 10M and 6M and above. On 10M they are restricted to 28.0 to 28.3 MHz for data modes. Techs are restricted to CW only on 80M, 40M, and 15M.
KC9NVP
« Reply #2 on: June 21, 2017, 07:10:33 AM »
If I recall in the Tech Lic manual there is a page with the band plan chart that lays out where Tech, General etc are allowed to operate.  Any place where it indicates Tech level and data would be locations where a Tech ticket holder would be allowed to operate digital mode.  If you miss placed your copy of the Tech Lic manual do a search on the internet for ARRL Band Plan and you should be able to find the chart.
73 and good luck,
David
KG6AF
« Reply #3 on: June 21, 2017, 11:18:36 AM »
The ARRL's Technician band chart:
http://www.arrl.org/files/file/Tech%20Band%20Chart/Tech%20Band%20Chart.pdf
Data segments are clearly marked.
N6ORB
« Reply #4 on: June 23, 2017, 03:30:03 PM »
Now is a great time to be on six meters running JT65 and MSK144. This year has seen a dramatic shift from phone to these digital modes on 6m. The improved ability of WSJT-X to decode very weak signals likely accounts for much of the shift.
Dave, N6ORB
N0IU
« Reply #5 on: June 24, 2017, 08:19:05 AM »
Stop going to those forums!! There is no grey area on the answer to this question.
NK7Z
« Reply #6 on: June 24, 2017, 09:10:38 AM »
Steve KA1OWC
Steve,
In your training to become a Technician Class license holder,  you probably should have been taught how to look up FCC rules...  A large number of questions within the current question pool for tech class licenses deal with how to use the FCC R&R.
Respectfully, you should know how to answer this question yourself, in an unambiguous way. See FCC part 97, part 301.
https://www.ecfr.gov/cgi-bin/text-idx?c=ecfr&SID=336ab7469b61ecbfa15086dbf1bf2c59&rgn=div5&view=text&node=47:5.0.1.1.6&idno=47#se47.5.97_1301
Not trying to be mean here, but if you don't know how to look up the rules, you really need to learn this ASAP, probably before you ever operate a transmitter.  It will save you getting an OO card, or an FCC notice of violation.
As an aside the ARRL also provides a handy guide to answer your question as well:
http://www.arrl.org/files/file/Tech%20Band%20Chart/US%20Amateur%20Radio%20Technician%20Privileges.pdf
Hope this helps.
Dave
For reviews and setups see: http://www.nk7z.net
WZ7U
« Reply #7 on: June 24, 2017, 03:04:28 PM »
Steve KA1OWC
I'm curious which forums these are, so i won't go there for information since they are obviously wrong. GL & have fun Steve!
WZ7U ~ originating from CN86jc +/-
Yet another imperfect being created by THE perfect God. Thank you Jesus!
W2UIS
« Reply #8 on: June 29, 2017, 04:59:13 AM »
Technician class has all operating prevlidges (as Genenaral and Extra) from 6 meters up. Band plans are not FCC regulations just a ARRL idea.
W2UIS
« Reply #9 on: June 29, 2017, 05:01:15 AM »
Best place for 6 meter JT65 is 50.276.
ND6M
« Reply #10 on: June 29, 2017, 05:10:32 AM »
...(edit)... Band plans are not FCC regulations just a ARRL idea.
HUH?Huh
in regard to operating PRIVILEGES, the ARRL bandplan is exactly the same as Federal Law.
WZ7U
« Reply #11 on: June 29, 2017, 01:57:49 PM »
HUH?Huh
Huh?Huh Since when does the ARRL have the full weight and authority of the Federal Government?
 I suppose if you mean that because the bandplan says I can't transmit on 13.985 that is the same as Federal Law.
That statement is confusing. Please elucidate.
W2UIS
« Reply #12 on: June 30, 2017, 03:56:46 AM »
My comment on the ARRL Band Plan is taken out of context.
W4KVW
« Reply #13 on: June 30, 2017, 08:42:05 AM »
HUH?Huh
The ARRL Band Plan is NOT Law.It suggests what mode should be used on any frequency such as LSB on 40 meter phone.There are several groups who use USB on 40 meters daily & they have for years.They are NOT violating any laws just not following the Band Plan.I'm sure others do this on other bands & the only band I see where it would be an issue is 30 meters but the rest it appears not so.  Shocked
Clayton
W4KVW
