Author Topic: Will 2.5 amp's run a TS-570D for listening only?  (Read 1258 times)
KM4RLT
« on: June 27, 2017, 05:30:44 PM »
Hello
Will a radio shack 12vdc 2.5 amp power supply run a TS-570D for listening only till I get my Astron RS-35M? I know I can't key down on it or tune it!
Thanks Jeff
WZ7U
« Reply #1 on: June 27, 2017, 06:18:18 PM »
Jeff,
  A simple go go on the duck (Duck Duck Go, a google competitor) produced this document - http://www.qsl.net/on6ab/TS570Schemazip/TS570D%20expanded%20test%20results.pdf
Quick answer, from page 7,  .78A receive. 3/4 of an amp approximately. Easy peasy.  Wink
Oh, just so you know, there are a contingent on the interwebs that would've scolded you for not looking that up yourself first. Mightily I'm sure. While I don't personally know of the level of your internet accessibility, might I suggest you try a simple google (or the equivalent) search of the question at hand. To avoid any future 'entanglements' with 'those' hams. Just sayin.  Grin
You should be fine. As you noted, it will not support transmit currents. Enjoy listening to all there is to hear out there.
Oh, and you're welcome.
73, Eric
WZ7U ~ originating from CN86jc +/-
Yet another imperfect being created by THE perfect God. Thank you Jesus!
« Reply #2 on: June 27, 2017, 06:38:34 PM »
Hello
Thanks Jeff
It draws less than 2 amps at normal volume. You will be fine.
KM4RLT
« Reply #3 on: June 27, 2017, 08:53:23 PM »
Thanks everybody I do Appreciate it
« Reply #4 on: June 27, 2017, 09:09:05 PM »
Jeff....  a quick check for your answer is to measure the voltage when you power up the receiver.  If it drops, then the power supply is overloaded.  This part can be done in a very short time.  (No voltmeter...go to Harbor Freight and get one for 5 bucks!)
Then, if the power supply voltage stays put then monitor the fingers the temp of the pass transistor or heatsink.  If those temps stays reasonable, then you're in like Flynn!  (Time for this part of the experiment, just a few minutes.)
KAPT4560
« Reply #5 on: June 28, 2017, 01:27:38 AM »
 Is this the Micronta regulated 12 volt supply from Radio Shack? If so, the 13.5-ish output voltage should be fairly stable both with or without load.
 These simple power supplies are RFI quiet, simple and serviceable. I have used them as a general bench supply when operating/repairing solid-state car radios and portables.
