Author Topic: yaesu 450D scope ?  (Read 2293 times)
KB2WVO
« on: August 25, 2017, 04:19:27 PM »
hello.. wondering if a way to add a band scope to a yaesu 450D Huh
i do have a SDR dongle. if that is needed... nothing special its the srl i think or strl one.. cheapo..
or am i brakin up a short tree ??
KB2WVO
« Reply #1 on: August 25, 2017, 08:00:16 PM »
yes i seen that board or whatever it was mod.. but
askin if something other then that board?? or diff ways of doing this Huh
« Reply #2 on: August 26, 2017, 08:05:11 PM »
Are you a member of the FT450 group on Yahoo?.  I think what you are asking has been implemented by several over on that discussion group.
KB2WVO
« Reply #3 on: August 26, 2017, 08:06:54 PM »
yeah i think iam.. ill search it..
thanks ..
just checked lol yep iam. but the name iam under is bad from facebook for 7 days. i spoke truth about a local news issue.. got to love the free press. lol cough choke..
« Last Edit: August 26, 2017, 08:09:37 PM by KB2WVO » Logged
VK4KX
« Reply #4 on: August 28, 2017, 08:04:08 PM »
You should be able to set up a Pan adapter for the radio.
KB2WVO
« Reply #5 on: August 29, 2017, 11:03:39 AM »
if you meen using the board made for it.. the ham is SK.. no more boards ....that i know of anyways..  i have the dongle..  RTL-SDR.   i can put up a antenna for 6 for the dongle RX only. and use it. it will work for now i guess.
KOP
« Reply #6 on: September 03, 2017, 10:10:21 AM »
From G4HUP
http://huprf.com/huprf/pat-board/
You need PAT 70 , Same as I use for the FT857D .
Hi-Z in , Lo-Z out
Does not load the IF (much if at all) and produces more enough signal for a RTL at the minimum.
This IF is approximately 70Hhz.
66 days, 9 hours, 55 minutes and 59 seconds
KB2WVO
« Reply #7 on: September 07, 2017, 07:52:59 AM »
From G4HUP
Hi-Z in , Lo-Z out
"Due to the sudden passing of G4HUP business is currently suspended."  from there own site..
there out of biz for now.. is why i was askin on here. but i found a way around the issue.. i just use my SDR with its own antenna.. not the greatest way but will work.. and i dont have to put anything in radio ..
