Author Topic: IC-910H TX power fail on 2m & 70cm  (Read 701 times)
VK4KX
« on: August 28, 2017, 06:57:02 PM »
I have an IC-910 with a couple if issues if anyone has come across this before.
The first one which kis minor in comparison is that when I have the UHF band in the second band below the main it will start scrolling or scanning in frequency, even if it's a memory channel and yes I have checked that it's not in scan mode.
Now here is the second issue!
It has just dropped in output power on both 2m & 70cm to an unreadable amount on an external meter and micro deflection on the screen power reading.
23 CM is ok as it's the add on module but I don't know what caused 2m & 70cm TX Power to fail as the SWR is good on both those bands antennas, perhaps I was rag chewing too long at high power.
Here in VK the cost of both sets of finals is quite high but they are available and for me this is a last option, so I'm thinking something prior to the output finals has failed.
Any help would be appreciated.
Regards
VK4KX, Bernie
