Author Topic: Hallicrafters sx-28 removal of frequency dial  (Read 1089 times)
W1LJD
« on: September 10, 2017, 05:23:23 PM »
Experienced Sx-28 restorers.  How do you remove the metal hub that holds the frequency wheel on the shaft..  there is a odd shape nut or is it pressed on??  i have pictures    its frustration almost done with the restoration..  any emails would be appreciated..  i have two brand new freq dials i want to install...  augie wa1jd[img
AC2EU
« Reply #1 on: September 10, 2017, 06:40:01 PM »
If memory serves, those have set screws holding the hub to the shaft.
In fact the main dial is on the variable capacitor, so you must be able to move it to coincide with the mesh calibration. rotate the dial and you should see them.
Have you pulled the chassis out of the box and looked at it closely?
K1ZJH
« Reply #2 on: September 10, 2017, 07:15:14 PM »
Both dial hubs should have set screws as I recall.
W1LJD
« Reply #3 on: September 10, 2017, 10:19:25 PM »
Yes classic out of cabinet. I do have the freq dial off the shaft
Want to replace the yellow freq wheel with new reproduction wheels. I cannot get the
Middle hub off the wheel to put on my new wheels. Augie
