Author Topic: 2m SSB - Amp/Pre or second antenna?  (Read 2810 times)
K7MWJ
« on: November 08, 2017, 08:27:35 AM »
In the past several weeks I have joined three others in my area in the beginnings of a VHF club, solely focused on SSB (phone, CW [need to learn], and RTTY). I put up an Cushcraft 148-10S yagi and have really good luck with it. I was able to make a couple phone contacts about 160 miles to the north on 30w.
I feel I could get bigger ears by either adding an amp/preamp (looking at the Mirage B-2518-G) or adding adding an ear with a second 148-10S antenna.
Thoughts?
Thanks!
73s - Mark
K7MWJ
« Reply #1 on: November 08, 2017, 09:04:19 AM »
I think you would be better off with the CC 215WB or 13B2 than stacking. Flip the other vertical for FM.
« Reply #2 on: November 08, 2017, 11:27:42 AM »
I fully agree.
The 10S yagi is small and hasn't much gain.   Use it vertically for FM and install a single larger antenna for weak-signal work.
N8EKT
« Reply #3 on: November 08, 2017, 04:29:23 PM »
You need a long boom yagi.
I had a 22 foot long KLM for 2meter ssb and a mirage b108 amp/preamp and did great.
The KLM put my Cushcraft Jr Boomer to shame.
AA2UK
« Reply #4 on: November 09, 2017, 10:08:49 AM »
I fully agree.
I agree your current antenna has little gain at 144.200. I suggest putting up the largest 2 meter Yagi you can. I'm in a restricted community so I am using an M2 2M9SSB it's a decent antenna given it's size. I still recommend using and getting low loss feed line, an external mast mounted LNA as well as the largest amplifier you can afford. In that order.
GL glad to see you're trying to promote local 2 meter activity. It's a great band and Q's out to 350 miles are common.
Don't overlook the digital modes using MSK144 (WSJTX) I routinely work up to 1000 miles daily.
73, Bill
AA2UK
K3GM
« Reply #5 on: November 11, 2017, 09:14:02 PM »
Considering your location, you're probably running out of good weather for antenna work.  But I think you'll see the largest return on investment with a long boom yagi like a Directive Systems K1FO or other brand.  I'd also look at low loss transmission line such as Heliax, and a mast mounted preamp.  The preamp used in the Mirage amplifier is borderline, and mostly just raises the noise floor.
....and if you decide to use your present yagi for FM (is it broadbanded enough?), you dont want a metallic mast to pass through the elements.  Mounting off to the side on an H frame is the way to go.
« Last Edit: November 11, 2017, 09:22:29 PM by K3GM » Logged
N3JDR
« Reply #6 on: November 15, 2017, 09:51:11 AM »
If you are serious about weak signal VHF/UHF, BOTH!
Pretty hard to go wrong with M2 or InnovAntenna.
Advanced Receiver Research (AR2), SSB electronics and SHFelectronik make good preamps.
AA2UK
« Reply #7 on: November 15, 2017, 04:33:36 PM »
Hello Bill, I agree with your choice of performance products for VHF/ UHF.
Bill, AA2UK
N2SLO
« Reply #8 on: November 22, 2017, 04:53:30 AM »
Mark- agree with comments on here. Order of priority is:
1) Best antenna you can buy and put up based on space (you can't work them if you don't hear).
2) Low loss COAX- LMR 400 is minimum to use
3) Mast mounted preamp- but for 2M not worth money for 2M SSB unless you have a very long COAX run. if you need one SHF in Germany - I have three of them for VHF and UHF bands and work great.
4) Amplifier- for low power TE Systems 1452G (20 in 300+ out with built in preamp)
is great for about $750. DX shop in UK has some great amps 300-500 watts, a little expensive but do it right once.
Hope this helps- good luck
David
« Last Edit: November 22, 2017, 04:56:33 AM by N2SLO » Logged
