Author Topic: repeater amplifier for fr5000  (Read 7583 times)
N1FMV
« on: January 05, 2018, 12:48:12 AM »
Hi all, our club is changing our repeater to an ICOM FR5000. I believe it is 25w full duty cycle or 50w half duty cycle. Are their any recommendations for an external power amplifier that will working reliably for us?
thanks
K4JJL
« Reply #1 on: January 05, 2018, 09:15:43 AM »
How low can the power go?  You can use a Motorola PA from an MSF5000 if you can get it down to around 5-7 watts by using pads or power settings.  You'll have to modify it to work without a control signal (detailed instructions on Repeater Builder website).  GE amps won't work because they take less than 1/2 watt to drive (unless you start cutting stages out of it).
You'll need to make sure your duplexer can handle the power, too.  If you have the cheap factory notch-notch one built into the Icom case, you'll burn it out in a week.
N8EKT
« Reply #2 on: January 05, 2018, 02:52:20 PM »
Henry sells a 30 in 100 out continuous duty rack mount amp for under $800
TPL makes better quality amps with 25 in 125 out for nearly twice the price.
