Author Topic: CDE TR44  (Read 1851 times)
WB8HWO
« on: February 26, 2001, 02:59:27 PM »
NEED PIN OUT TO WIRE 8 CONDUCTOR CONTROL BOX AND ROTOR MOTOR.
THANKS FOR YOUR HELP.
« Reply #1 on: February 26, 2001, 05:15:47 PM »
Why?  The TR44, CD45, CD45, Ham-M, Ham-II, Ham-III and Ham-IV all have exactly the same wiring, whether the brake pin (Ham-M series only) is actually used or not.  Pin #1 on the rotor = Pin #1 on the control box, etc, up to Pin #8.  The actual function per-pin is irrelevant unless you're homebrewing a control box.  Pins #1 and #2 are the heaviest-drain pins (motor and brake), so if you have rotor cable with two larger conductors and six smaller ones, the two larger conductors should be used for pins #1 and #2.  In most rotor cables, these two conductors are black and white.
Steve WB2WIK/6
AB0PZ
« Reply #2 on: February 28, 2001, 02:14:07 PM »
e-mail me and I'll e-mail you back a copy of the manual in pdf format...
Harry
AB0PZ
harry@earth2.net
