Author Topic: Roller Inductor noise  (Read 1248 times)
W4CWA
« on: October 10, 2001, 10:37:36 AM »
I have had a Vectronics 1500 antenna tuner for 4 years.  Recently I have noticed when I turn the inductor, noise/pops can be heard in the RX and the antenna analyzer indicates that the connection is intermittent.  When the inductor is not turned, the connection appears to be ok; although it can be tricky to find a spot on the inductor that make a clean connection.   I never run more than 150 watts through the tuner.
Is there something that can be done to the roller inductor to maintain a better connection when turning?
Are there some roller inductor tuners that do not have this issue?
Thanks for any help.
Frank W4CWA
« Reply #1 on: October 10, 2001, 11:09:32 AM »
Probably just dust or tarnish in the contacts.  A bit of elbow grease
and/or silver polish would probably clean it up.
I have often seen this problem with surplus ARC-5 roller coils.
Some roller inductors may provide more of a scraping contact which
tends to keep the contacts cleaner, but any moving contact in
any equipment will be prone to fouling over time.
« Reply #2 on: October 10, 2001, 01:04:48 PM »
I've seen something similar in most every roller-inductor product (antenna tuners and amplifiers) I've ever used.  Unfortunately, it's very difficult to keep even, sufficient tension between the roller contact and the coil itself due to small dimensional variations in the coil, varying spring tension which occurs with age and use, etc.
I'd use a soft, clean cloth to wipe the inductor clean and check the tension on the coil element provided by the sliding or rolling contact.  If there's any way to increase tension, give this a try.
If you think what you're seeing is "interesting," you should see what happens when you have intermittant contact on a roller inductor in a 10 kW transmitter!  That can be quite spectacular, in terms of sparks, flames, smoke...
73 de Steve WB2WIK/6
« Reply #3 on: October 10, 2001, 11:56:39 PM »
Rub the moving parts down with a lint-free cloth wetted with WD-40, you might be surprised at how well it cleans up. I'm also becoming fond of using Valvoline semi-synthetic Dexron III transmission fluid as a lubricant/cleaner. About $3.00 a quart at your favorite auto parts store.
G4HZV
« Reply #4 on: October 12, 2001, 01:53:55 PM »
Most of the ham tuners use roller inductors with wheel contacts. If anyone's building from scratch or can look inside before buying a boxed unit, then look for roller inductors with the rubbing block contact. These tend to be self cleaning and more reliable then the wheel contact units.
