Author Topic: Rebuilding a Clipperton L  (Read 173 times)
K9SMC
« on: November 10, 2001, 08:00:26 PM »
Where is a good source for capacitors, diodes, resistors, etc to rebuild this amp?  Any good suggestions are also welcome.  Amp is intact, but was stored for 15 years, prior owner was a heavy smoker.  Need to clean amp also, any suggestions?
Steve K9SMC
« Reply #1 on: November 10, 2001, 08:12:20 PM »
I might suggest you locate a variac ( veriable transformer) for the 110 or 220 , its easy to switch the input voltage on the clipperton L, start at 30 volts,then 60  etc. a half hour or an hour at a time.. word has it that it helps the caps rebuild them selves and is in general good for the rig.. some folks do 6 hours each step and raise it 15 or 20 volts a step.. it can't hurt..I have one and another on the way and I really like it.. good little desk top kw.. and I picked up a 110 veriac and a 220 veriac on ebay for about $20 plus shipping..tom N6AJR
RobertKoernerExAE7G
« Reply #2 on: November 10, 2001, 08:19:32 PM »
There have been prior postings asking about getting rid of smoke gunk.  Also an article in QST a few months back.
W7DJM
« Reply #3 on: November 10, 2001, 10:19:04 PM »
As old as that thing is, I would not waste my time with a variac.   WHEN  one of those caps decides to "go" later on, it could (will) make a big mess, and smell.   Just replace them, now.
Actually, you really don't need a Variac.   You can wire up a light bulb in series with the amp, to limit the current.   Start with (guess) with 40, 60w lamp and go on up to 150w or so, and let it "cook" there.
Digikey, Mouser, are at least two places that sell filter caps.   You may have trouble getting exact size replacements, but it is a simple matter to make a small perf board and mount the new caps on, which will be MUCH smaller than originals, for the same ratings.
W9GB
« Reply #4 on: November 12, 2001, 01:03:42 AM »
Steve -
Here are a few interesting pages on the Clipperton L
Tom's Tubes conversion to Russian gi7b tubes
http://www.tomstubes.com/amp-conversions/
QRO home page
http://www.nd2x.net/base-1.html
Economy Electronics
http://www.economyelectronics.com/
MGS
http://www.mgs4u.com/
That should get you started
w9gb
