Author Topic: Screwdriver antenna plans  (Read 6612 times)
WH6CVF
« on: November 19, 2001, 04:40:57 AM »
Dose anyone know how or where i can get some plans to make a screwdriver antenna.
So far I've had no luck at all.
Please can anyone help me.
Thank you so very much.
Sincerely,
Linn
Wh6CVF
AC5E
« Reply #1 on: November 19, 2001, 07:08:08 AM »
Hi: Worldradio used to publish a book, as best I remember by Don Johnson, W6AAQ, with fairly detailed plans for a screwdriver antennas. I don't know if they still carry it, but it's worth a try. If they don't I have seen several copies in piles of old magazines at hamfests.
  73  Pete Allen  AC5E
W4SIH
« Reply #2 on: November 19, 2001, 12:49:52 PM »
If you dont find what you need using the above info you might write Don Johnson W6AAQ direct ,he has (or had )a 17 page manuscript available on all the info needed to build a screwdriver antenna.the cost was less than $10.
KG4MGC
« Reply #3 on: November 21, 2001, 12:22:02 AM »
Try this site.
http://www.hamradio-online.com/1996/oct/screwdrv.html
73, Buddy KG4MGC
W7DJM
« Reply #4 on: November 21, 2001, 06:32:49 PM »
As above, and by the way, Mr. Johnson was pretty much "the guy" who pioneered this concept, at least as relating to using a "screwdriver motor" for tuning.
WD9ACQ
« Reply #5 on: November 23, 2001, 09:07:11 AM »
I have the "complete" plans on how to build W6AAQ's DK3 Screwdriver antenna.
The plans are very detailed and is easy to build.  If you still need plans let me know
 and can send a copy to you.
 email me at  wd9acq@qsl.net
73d de Al  WD9ACQ
