Author Topic: Kenwood TS 2000 & Heathkit SB 200 Linear  (Read 3071 times)
KB1GZ
« on: December 18, 2001, 01:16:55 PM »
Can someone provide information to properly hookup the Heathkit SB 200 linear to a Kenwood TS 2000?
« Reply #1 on: December 18, 2001, 01:35:03 PM »
You'll need to modify the amplifier, or build or buy an external keying interface.  The SB200 has a high voltage keying line which must be grounded on transmit, and the TS2000 keying circuit cannot handle the high voltage.
The Ameritron ARB-702K will do this job for you, if you don't want to make modifications or build your own keying interface. It comes with very complete instructions for connection.
73 de Steve WB2WIK/6
AC5E
« Reply #2 on: December 18, 2001, 03:40:22 PM »
Hi: Harbach has a keying line mod kit for the SB200. It's easy to install, and works FB.
  73  Pete Allen  AC5E
KE4MOB
« Reply #3 on: December 18, 2001, 06:31:57 PM »
Or build the interface box yourself from plans on the ARRL TIS website.
Steve, KE4MOB
PA3DUV
« Reply #4 on: December 19, 2001, 05:35:27 AM »
Or check http://www.vcnet.com/measures/ for tr switch conversion.
Dick PA3DUV
