Author Topic: HAM-IV box on a T2X rotor?  (Read 686 times)
N3RU
« on: January 08, 2001, 11:43:38 PM »
Hi.  I understand that a HAM-IV control box can be used with a Tailtwister rotor.  My question is- The HAM-IV control box has a 8-pin plug and the rotor has a 8 conductor terminal block.  How do the pins of the plug match up with the 8 wires from the rotor?  Do the pins just go straight across like the T2X control box with the terminal block, or does the plug use some other arrangement?
Thanks.
73, Bob N3RU
bobz@adelphia.net
NT6B
« Reply #1 on: January 09, 2001, 12:32:17 PM »
BOB...THE 8 PIN CONNECTOR ON THE CONTROL BOX AND THE ROTATOR ARE IDENTICAL AND THE WIRING IS PIN FOR PIN FOR BOTH SERIES OF CONTROL BOXES AND ROTATORS...IE PIN 1 ON THE CONTROL BOX GOES TO PIN 1 ON THE ROTATOR AND SO ON...ON SOME EARLY MODEL TAILTWISTER ROTATOR CONTROL BOXES  THERE WERE NO INDICATOR LIGHTS BUT LATER MODELS OF CDE AND HYGAIN ALL HAD THEM...LESS THE INDICATOR LIGHTS, THE BOXES ARE INTERCHANGEABLE...THE IS A EASY SWAP FOR YOU.....73'S....LONNIE  (NT6B)
K0XU
« Reply #2 on: January 09, 2001, 08:18:26 PM »
You need to talk to someone who has a manual for the HamIV rotor and see what the pinout is. Hy-Gain used to sell the pigtail to update the rotor or control, don't know what MFJ is doing along that line. You might e-mail their customer support on their web page.
www.mfjenterprises.com
W9GB
« Reply #3 on: May 19, 2002, 10:05:38 AM »
1. Can I use a Ham-2 rotor control box with my T2X rotor? Are the Ham-2, Ham-3, Ham-4 and T2X control boxes interchangeable?
Yes, for the most part, all of the 8-wire rotors except for the TR-2 series are interchangeable. You can use a TR-44 series 3; Ham-M series 3, 4, or 5; CD-44/Ham-2; CD-44/Ham-3; Ham-4; or T2X control unit with any of the listed rotors or vice versa. However, the Ham-M and TR-44 series 1 and 2 rotors were wired differently and are not interchangeable with anything else. So trying to use a series 1 or 2 control on a newer rotor will destroy the rotor pot instantly.
To be sure that you have one of the interchangeable controls, verify that the motor start capacitor is across terminals 4 and 8. To verify that the rotor is one of the interchangeable models, look for the 500-ohm pot resistance across terminals 3 and 7. If your rotor and control unit pass these inspections, they are interchangeable with others which also pass.
2. Which is better, the 51465 terminal board, the Amp plug, or the Cinch-Jones plug, directly wired to the rotor on my Ham-4 or T2X?
The 51465 terminal board supplied by Hy-Gain uses plated terminal screws which will often rust within days of installation. At Norm's Rotor Service we supply the same terminal board with stainless screws. These boards have survived very well for years with little or no corrosion. This is highly recommended; it is available as part number 51465S. The Amp/Cinch plugs that Hy-Gain and CATS are supplying are okay, but they are not rated for the solenoid current. These must be totally waterproofed to prevent water from getting into the connectors. They also make servicing of the rotor much more difficult.
3. What is the difference in the Ham series of rotors?
The Ham-M rotor was released in 1957 and there were 5 series with the last rotor being produced in 1973. The Ham-M rotor would have the series number, 1 - 5, followed by 3 digits which indicated the week and year of manufacture. For example, a rotor with the series number 5 322 would be a Ham-M, series 5, manufactured in the twenty-second week (the '22' in '322') of the year 1973 (the '3' in '322')
A Ham-M has a single-levered control box with a meter. In 1973 the mold for making the Ham-M control unit shell was destroyed in a fire. So rather than spend the money to replace the mold, the Ham-2 was born. The rotor was the same as the Ham-M, but the control unit was replaced with a three-button unit with a continuous meter reading.
In 1977 the Ham-3 rotor was released. The Ham-3 supported a new motor with an internal brake, as well as a brass motor gear. The brake wedge was redesigned, as was the brake housing, which gave the new unit a capacity for more wind surface area. The control unit for the Ham-3 supported a new PC-board-mounted meter.
In 1978 the Ham-4 or Ham-IV rotor was released. This rotor had a new steel ring gear and a reinforced upper mast support. The only changes to the control box were the addition of a new face plate, plastic top and bottom covers, and a new meter with reversible meter scales. Also in 1978 the TailTwister rotor, commonly refered to as the "T2X," was introduced. The T2X is a Ham-4 with an even heavier upper mast support, a heavier brake wedge and brake housing, and 40 additional ball bearings. And the TailTwister control unit has three LED's that the Ham-4 doesn't have.
4. What is the color code for the cable connecting my rotor and control box?
The colors vary from manufacturer to manufacturer. But it really doesn't make any difference, as long as you make sure that you're connecting terminal 1 on the rotor to terminal 1 on the control box, terminal 2 to terminal 2, and so on. Also, on the HAM series and T2X rotors, you need to be aware that the heavy wires must go to terminals 1 and 2. After that, a lot of people (including Norm) like to use the resistor color code, just because it's easy to remember. If you want to do this, you can just use the wires in the order of the resistor color code: black, brown, red, orange, yellow, green, blue, violet, grey, white.
http://www.rotorservice.com/
w9gb
