Author Topic: Testing a 4CW10000(Y442) without socket???  (Read 3555 times)
KD7YQM
« on: August 07, 2008, 12:10:43 PM »
I recently acquired this bad boy and I really can't think of any way to do any preliminary testing on it without a $400 socket.
I've checked the usual continuity of filament and shorts between elements and all looks good.
Another thing is that this thing will draw 75 amps @7.5v.
Not exactly an easy to find transformer.
Sounds more like a welder;)
Thanks for any ideas.
Dennis
K4DPK
« Reply #1 on: August 07, 2008, 02:33:41 PM »
Dennis...
Is that a coaxial base?
I have several rings from large sockets.
Give me the diameters and I'll see if I have the rings/finger stock that fit.  I could send them out just to test.
Phil C. Sr.
k4dpk
KD7YQM
« Reply #2 on: August 07, 2008, 02:54:08 PM »
Hi Phil
Yes it is a coaxial base. The recommended socket is the SK300A. There's one on ebay for $400. Such a deal.
Eimac gives the ID dimensions for the filament connections as 1.9 inches for the inner and 3.17 inches for the outer contact.
The screen OD is about 4 inches and the grid OD is 3.8 inches.
Let me know what you have and what you want for it. Maybe I could build a socket cheaper. Doubtful though. thanks Dennis
K4DPK
« Reply #3 on: August 07, 2008, 05:35:36 PM »
Dennis...
Send me an e-mail, and I'll send you some pix and dimensions.
I'm good in qrz.com
Phil
« Reply #4 on: August 08, 2008, 09:43:41 AM »
$400 for a socket is not a bad deal at all.  This is obviously a water-cooled tube with reservoir and circulator requirements for DI water, as well as enormous power resources required; I think the socket cost is probably the "smallest" investment associated with building such an amplifier!
AD4U
« Reply #5 on: August 08, 2008, 10:55:10 AM »
A 4CW10000 (Y442)amp may be difficult to "tame", because it will probably have to be operated in class AB.  This is not a project for a first time amp builder.
If you want to build a big amp, a 3CX10000A7 or a 3CX15000A7 would be a better choice.  It will operate in typical grounded grid configuration, and 1500 watts in should give 15,000 - 20,000 watts out.
CU on 20 meters.
Dick  AD4U
KD7YQM
« Reply #6 on: August 08, 2008, 11:03:39 AM »
You are right on all counts Steve. I just thought I would try to determine the condition of the tube before investing in the spendy stuff. Since the tube only cost me $30 I didn't feel spending $400 on a socket just to test it. Well if that socket is such a good price people should be snapping them up. I don't see that.
Interestingly this tube is physically smaller than the 4-1000 albeit a whole lot heavier.
Funny I just wound me a transformer that is capable of 5kw. I thought it was way too large at 80 pounds. You probably couldn't get half power out of this tube with it. We'll see what I can do with it.
Dennis
KD7YQM
« Reply #7 on: August 08, 2008, 11:19:41 AM »
Hi Dick
Yes I know this could be a difficult and costly endeavor.
I don't even know the condition of the tube yet. That was  the whole purpose of this thread. The filament tests good with a ohm meter and nothing seems shorted. An emission test would tell the story though.
Being a tetrode I would say this would make a good grid driven amp operating AB1.
At this point I just want to try and get the filament lit.
Dennis
P.S. Anyone have any pics or schematics of this tube being used in an amp? Even a rf heating generator would be interesting to look at.
AD4U
« Reply #8 on: August 08, 2008, 11:35:00 AM »
Hi Dennis:
I am writing this with a sneaky grin on my face.
I have learned a little in my 40 years of hamming.  One thing is when you go "horse racing" with the big boys with big amps, I don't care what you have, somebody will have a bigger one.
All this is posted in semi-jest, but in order to power such an amp, you would need at least a dedicated 240 volt 200 amp service.  A suitable filament transformer may be hard to find, and you may have to wind one.  The simplest plate transformer would be a reverse fed 25 KVA power company "pole pig".
Been there and done that.
Good Luck
Dick  AD4U
KD7YQM
« Reply #9 on: August 08, 2008, 11:58:54 AM »
I think you are right about the 25KVA pole pig Dick.
Absolute maximum ratings on this tube are 7500v at 3amps
That comes to 22500w
I think about 100amps at 240 should do it.
Boy that should dim some lights, huh?
I guess I don't have to run it at max but considering the 500w filament it would be nice to get a little more than that on output! ;>)
« Reply #10 on: August 08, 2008, 12:32:52 PM »
>RE: Testing a 4CW10000(Y442) without socket???       Reply
by KD7YQM on August 8, 2008    Mail this to a friend!
Hi Dick
I don't even know the condition of the tube yet. That was the whole purpose of this thread. The filament tests good with a ohm meter and nothing seems shorted. An emission test would tell the story though.<
::It will tell something, but not whether the tube is actually good unless you hipot test it or apply full rated plate voltage.  I don't know how long you can dissipate any power before water cooling is required, but probably for "seconds" would be okay.
WA4ONV
« Reply #11 on: August 10, 2008, 07:08:57 AM »
What ever happened to QRP ops...Huh   lol
Vy 73, Joe
WA9SVD
« Reply #12 on: August 12, 2008, 06:42:48 AM »
To SOME people, that IS "QRP."
    But has anyone (else) noticed the electric rates lately???
K6ELQ
« Reply #13 on: August 15, 2008, 02:36:11 PM »
Here's a link to the SK-300A socket dimensions in case you want to roll your own.
http://www.g8wrb.org/data/Eimac/SK-300A.pdf
KD7YQM
« Reply #14 on: August 15, 2008, 03:10:41 PM »
Thanks K6ELQ for that info.
