Author Topic: FL-2100B  (Read 747 times)
KE5EKO
« on: August 20, 2008, 07:09:07 AM »
I purchased an FL-2100B as my 1st amp and have a question/problem. The amp works fine on 15 thru 80. Voltages/currents all within normal limits and power out is fine. BUT it will not tune on 10m. Someone suggested that the 10m mod needed to be accomplished. I'm having trouble finding that information..Any help or suggestions would be greatly appreciated....Thanks....Mike
W5RKL
« Reply #1 on: August 20, 2008, 07:23:35 AM »
I'm not aware of any required 10 meter modifications to the FL-2100B. The only modification I'm aware of is the bias modification required when using Svetland 572B's in the FL-2100B (see the Svetland website for further details).
When you say 10 meters isn't working, what do you mean?
It's possible a previous owner used the FL-2100B on 11 meters and tuned the 10 meter tuned input network for 11 meters. I suggest checking the 10 meter tuned input network first.
Mike
W5RKL
TANAKASAN
« Reply #2 on: August 20, 2008, 08:23:15 AM »
The version without 10m was the FL-2100F, not the FL-2100B. Your problem may be with the bandswitch so have a look at the following URL which may give you some clues.
http://foxtango.org/amplifiers/FL%20Amplifier%20Evolution.htm
Tanakasan
KE5EKO
« Reply #3 on: August 20, 2008, 05:10:27 PM »
I went thru the tuning procedure in the manual(disconnecting the high voltage-putting an SWR meter between the amp and radio, tuning the coils for the lowest SWR, etc.) but didn't see any variation when tuning the 10m coil...the other coils for the other bands tuned just fine....hope this helps explain my situation....thanks....mike
W5RKL
« Reply #4 on: August 21, 2008, 08:20:16 PM »
If adjusting the 10 meter coil didn't change the symptoms, then I agree with the Tanakasan, check the band switch. I also recommend check the continuity through the 10 meter coil, it may be open or one lead of the coil may be broken at the band switch.
Mike
W5RKL
KE5EKO
« Reply #5 on: August 22, 2008, 05:29:00 AM »
Thanks to all that replied.....I now have a place to start looking....73....Mike
