Author Topic: LINEAR AMP CABLE FOR YAESU FT-2000D  (Read 1077 times)
9K2AI
« on: September 17, 2008, 12:14:26 AM »
Hi all Looking for YAESU FT-2000D LINEAR AMP CABLE and one of my LINEAR AMP is Yaesu FL-7000. Thanx & 73's
K4CAV
« Reply #1 on: September 17, 2008, 05:03:11 PM »
Have you looked into the T9207451 10 pin din cable? I use that cable with my FT-950. I believe it is used with the FT-2000 as well. Look in the manual. Yaesu can furnish it.
Jim K4CAV
G8UBJ
« Reply #2 on: September 19, 2008, 08:02:28 AM »
Have a look at the N4ATS site
http://www.n4ats.com/?Band_Data_Cable_Info
it lists the band switching cable info. Actually both ends are standard connectors and so this would be easy to make up yourself.
http://www.n4ats.com/?download=D4000019_Schematic.pdf
ALC and PTT are straight phono sockets to the FT-2000
Be careful with drive level. You may wish to use the service set up to adjust them for each band ensuring you don't overdrive your amp.
73 G8UBJ
N4ATS
« Reply #3 on: September 23, 2008, 09:34:04 AM »
Hi , if you use the band data output from the FT2K you will only need the additional ALC cable  , PTT is worked thru band data therefor not needed. We also build the cables if you can not locate parts.
9K2AI
« Reply #4 on: September 24, 2008, 06:19:21 PM »
Thanx all you are great big 73's
