Author Topic: HM118TN Microphone for Icom 706 MK11G  (Read 1252 times)
WA2ARQ
« on: September 28, 2002, 08:16:21 PM »
Need help with this mike. Bought it new, out of the box, and did not receive any info sheet on how to use it. Any help would be appreciated. Thanks.
KG4TUL
« Reply #1 on: September 29, 2002, 07:32:23 AM »
Well, I'm not an expert, but it's just a standard DTMF microphone.
If by "how to use it" you are wondering how to the keypad, then that will likely be dependent on the station you are connected to. Generally, if you want to send DTMF tones to a radio, you just hold down the PTT switch and press the keys with your other hand. E.g., one of our local repeaters allows you to access an "echo test" with <#1>. In that case, you simply press the PTT switch, announce your call, and continue to hold town the transmit button while you hit the <#> key then the <1> key, and then say something. Ditto re keypress combinations to activate the IRLP link, etc.
Is that what you were asking?
Skip (KG4TUL)
KB0ETC
« Reply #2 on: September 30, 2002, 05:32:25 AM »
The Icom HM118TN DTMF microphone is exactly that.  A DTMF microphone.  All you can do with it is send DTMF tones.  And as with the stock micrphone you can use the UP/DN buttons to change frequency, or send CW as a paddle (MENU CONFIGURABLE).
I chose it only for repeater (6/10 meter) operation, and didn't expect much more from it.  I do like the large size, and seems to have a little more puch on HF than the stock microphone.
It would be nice to do direct frequency entry!  If you decide to buy any more ICOM accessories, don't buy the UT-102.  It is terrible at best compared to other voice synthesizers.
73's Brian (KB0ETC)
KB2CWN
« Reply #3 on: January 22, 2013, 01:36:17 PM »
This HM118TN mic came with my older 706. I received horrible audio reports saying RF in audio on SSB. Seemed to work fine on FM. Purchased a modular jack and plugged in my SM8...Problem solved! I do not recommend this hand mic for older original IC 706's. May work fine on the 706 MKIIG, but if you own a first gen 706....Stay away.
W9GB
« Reply #4 on: January 22, 2013, 07:15:01 PM »
Icom Global Support (Japan)
Manuals -- HM-118TN is not listed yet, BUT you can ASK.
http://www.icom.co.jp/world/support/...chcode=Options
Icom America Inc.
2380 116th Avenue NE,
Bellevue,WA, 98004, U.S.A.
Tel : (425)454-8155
Fax : (425)454-1509
http://www.icomamerica.com/
Support form
http://www.icomamerica.com/en/contac...ContactType=TS
Knowledge Base Article 6C5A251178
Issue
HM-118 Modification Instructions
RJ45 mic connector to 8 pin mic modification
http://www.icomamerica.com/en/suppor...?Download=1467
Knowledge Base Article 71AA165222
Issue
HM-118T Hand Mic Modification
Modification for the following radios:
IC-746, IC-718, IC-756, IC-756Pro, IC-820H, IC-821H, IC-910
http://www.icomamerica.com/en/suppor...?Download=1526
Icom HM-98/HM-133
http://tinymicros.com/wiki/Icom_HM-98/HM-133_Internals
w9gb
« Last Edit: January 22, 2013, 07:18:11 PM by W9GB » Logged
