Author Topic: Negative voltage regulators  (Read 627 times)
K0IPG
« on: October 26, 2002, 07:57:09 PM »
Hello all,
   I have about four dozen negative voltage regulators (7906's and 7912's, I believe) that I found in the junk box. I really don't have a need to regulate negative voltages, but postive ones would be nice! Is there any way I could use these for postive voltage regulation, without a prohibitive amount of extra circuitry?
   I understand the best thing would be to have postive voltage regulators, but I just hate to see a good part go to waste Smiley.
Dan
AC5UP
« Reply #1 on: October 26, 2002, 11:11:29 PM »
The only difference between a positive and negative regulator involves which side of the circuit is held at a constant reference level... A negative regulator works 'upside down' by adding a variable series resistance to the negative leg of the circuit.
This is not a problem for a simple circuit that doesn't care about an absolute ground reference, like pilot lights or an LED display. For something like a low-level preamp that doesn't draw much current you can bypass the negative leg with a series capacitor so the AC signal component will continue to see a common ground. You can also add an 'NPN wrap-around' pass transistor to increase the current capacity.
With that said, I wouldn't trust a work-around that doesn't have a true DC ground reference, no matter how clever, as a power supply for anything of value. Considering how cheap TO-220 regulators can be found, better you should keep the negative regulators in the junk box against the day you decide to tinker with op amps that need a split power supply.
- AC5UP
Have you considered how many wireless devices are in simultaneous use near PyeongChang, South Korea?  The TV coverage alone requires thousands.  Then add in the cell phones.  Talk about a pileup......!
