If you DO find that you have a problem, an AM broadcast
receiver does make a reasonably good DF receiver. In
most cases the ferrite rod antenna runs horizontally
the width of the case, and signals will be weakest when
the END of the rod is pointing at the signal. So if
you rotate the AM receiver to minimize the noise, the
likely location is in the direction of one of the edges
of the case. (It will not, however, tell you WHICH
edge is pointing at it, but if you take several
bearings from different points, you should be able to
figure it out.)
One problem with using an AM Broadcast receiver for
tracking power line noise is that the power wire act
as long antennas, and you may find a "hot spot" that
actually is some distance from the problem. (If you
think of the current distribution on a long wire
antenna, current peaks - where radiation is greatest -
are 1/2 wave apart. At 1 MHz this is 500' (150m).
Also, when you get close to the source it may be
difficult to take a bearing because the noise activates
the AGC regardless of the direction the radio is
pointing.
Once you have a good idea of the general area to look,
a VHF AM receiver with directional antenna is better
for pinpointing the exact source. If you have a
scanner, the only addition may be a directional
antenna. This need not be hard to build. First, check
your scanner manual to see what modes it uses on which
frequency ranges. (If you can switch in AM mode on
any frequency, so much the better.) You then need an
antenna for a frequency where the scanner works on AM.
Something in the 240 - 400 MHz range might be a good
choice, though if you can switch to AM on a ham band
you may have other uses for the antenna later.
A convenient sized antenna is about 3' (1m) long. This
will accomodate more elements (and have better
directivity) as the frequency goes up, but even 3
elements on 2m will be quite useful. You can make a
simple one by sticking pieces of aluminum wire or
brazing rod through a piece of PVC pipe for the boom.
Exact dimensions will depend on the frequency you want
to use, but
www.cebik.com has some good designs for the
ham bands.
You will find you have to be closer to the noise source
to hear it with the VHF receiver, but you now can swing
the antenna vertically and horizontally to find the
strongest signal. BE CAREFUL AROUND THE POWER LINES -
DO NOT LET THE ANTENNA TOUCH ANYTHING!
Then call the power company and report the nearest
pole number.
You may be able to use another type of detector - your
ears. There is a loose splice wire on a line about
1/4 mile from my house, and I can hear it jingling as
I walk down the road. In fact, I can hear it from my
house on a quiet night (we're in the country). There
is a high level of RF noise coming in the powerline,
especially on 80m and 160m. The noise was pretty high
on a long wire fed against ground, but a balanced
dipole or loop was no problem (even if I didn't use a
balun).
