Author Topic: What antenna to use  (Read 731 times)
NX1G
« on: June 18, 2003, 07:21:45 PM »
If you wanted to work 6-80 meter SSB and could put up no towers and had only medium height trees at 45-50'. What would you fellow hams recomend for the best bang for an antenna. Thanks, Steve, NX1G
« Reply #1 on: June 18, 2003, 07:39:01 PM »
I reccommend a multiband dipole also called a fan antenna.  do an elmers search on fan antenna  here on eham
AD7DB
« Reply #2 on: June 18, 2003, 09:35:01 PM »
How far apart are those trees, what kind of layout? Because if you can put up a horizontal loop, aka "Loop Skywire" with 4 sides about 70 feet apart, or nearly any polygon encompassing as much area as possible with a perimeter of around 280 feet, then you'd have a great NVIS antenna for 80m and 40, and good angles for working DX on 20-10; and it would also work on 6m. Feed 450 ohm twinlead into an antenna tuner with balanced output, and you'd do mighty fine there.
W2AEW
« Reply #3 on: June 20, 2003, 12:43:20 PM »
If the trees don't allow you to put up a loop like the previous post, you could try the ole' 1930's "all-band" dipole style antenna.  135' overall length, center-fed with 450 line to a balanced tuner.  I built mine for about $20 and it works very well.  Good for mostly local stuff on 80. 40 and up it works better and better.  By luck, mine is resonant on 17m (wierd), I put the tuner in bypass and just use the built-in balun.  It's a compromise antenna, but cheap, easy and quick.
I have a friend that uses a commercially available antenna called a "spider-cone".  Its a form of a fan-dipole that looks like a bowtie when viewed from the sky.  He's very happy with it.
Get yourself a spool of wire from Home Depot or Lowes, throw some wires in the trees and experiment.  Everyone's property is different, so there is no one "best" antenna for every situation.
My YouTube channel...
...ham radio, basic electronics tutorials, etc.
http://www.youtube.com/w2aew
