2 x MBM48 elm. or 1 x homemade MBM 92 elm
(1/1)
Jannes van Bergen:
I recently bought myself a second Jaybeam MBM48 this is a 48 elm 70cm antenna. (And there used to be a MBM88 aswell with a gain of just 19 dBd !! not dBi)
Now I can either stack them (2x48elm) or homebrew an extra long 92 elm beam .
Gain of 48 elm = 15,7 dBd open. 26 degrees
Gain of 92 elm = > 19 dBd open. <19 degrees
Stacking (+ 2dB?) should hardly effect the horizontal open. angle of 26 degrees but there will be some loss due to extra connectors and cable.
( boom approx. 6')
Homebrew a 92 elm will give me open.angle of just 19 degrees which makes it a very narrow beam but it will also provide me with
a wacking >19 dBd gain. ( boom approx. 12' )
Should I go for the stack or gain........
What is your expert opinion ?????????
Steve Fletcher:
That's an interesting question !
I think stacking would realise 2dB overall (including harness losses), maybe a bit more. So pretty close to the expected 92ele gain.
How many QSOs do you lose at the moment because the other guy can't hear you ? Would the extra 1dB from a 92ele make the difference ?
On the other hand, how many QSOs do you have now (on the single 48ele) where you have to tweak the rotator because the other station is a few degrees off ? Would you lose these contacts with an ultra narrow beamwidth ?
I think the old Jaybeam 88ele had a 'trombone' type support because of the weight/length of the aerial. You would have to make something similar if you go the 92ele route.
On balance I would probably stack. It's easier to do mechanically and in a location such as yours where contacts could be coming from almost any direction the beamwidth would be worthwhile . . . on the other hand there would always be the odd one that got away where that extra dB would have clinched it :-)
I'll point my own Jaybeam 48ele over to PA and look out for you.
73 Steve, G4GXL
www.g4gxl.com
Navigation
[0] Message Index
