Author Topic: U.S.N. VRC-51 TRANSCEIVER (140 MHZ)  (Read 654 times)
KC8ZBT
« on: March 21, 2004, 03:20:23 AM »
I HAVE A U.S.NAVY VRC-51 TRANSCEIVER WITH CONTROL HEAD.
OPERATES ON 138 ~ 141 MHZ AS FAR AS I CAN TELL.
I THINK IT MAY TUNE TO 144...
ANYBODY HAVE INFORMATION ON "THIS OLD TRANSCEIVER" ?
73 !
GREGG
ECLAMPSUSVITUS@HOTMAIL.COM
N3ZKP
« Reply #1 on: March 21, 2004, 10:26:46 AM »
I don't know, but your computer keyboard seems broken. The caps lock key is stuck in the ON position.
All caps is very hard to read and is the online equivalent of SHOUTING. Smiley
Lon
W4TYU
« Reply #2 on: March 21, 2004, 10:42:55 AM »
The poster is simply using a "Western Union" keyboard which is the standard for telegraphers and radio operators. As easy to read as the headlines on a newspaper.
KG8JF
« Reply #3 on: March 21, 2004, 11:02:15 AM »
get a life!
KG8JF
« Reply #4 on: March 21, 2004, 11:06:46 AM »
The "get a life" was directed at N3ZKP for his obviously sarcastic remark about the guy using all caps.  I don't know who, in the "letter police", started the rule about all caps, but it does not harm me and perhaps he has a good reason to do it.
« Reply #5 on: March 21, 2004, 01:33:15 PM »
Yes, he obviously wants to start a baloney thread.  Would you like some cheese with your whine and baloney?
To answer--
More than likely the rig can be easily converted for use on the ham bands, but I doubt that it could just be used as is.  It would have to be centered and re-aligned for the new range of frequencies--even though that range is just above its current range.
« Reply #6 on: March 21, 2004, 06:23:09 PM »
HAVE YOU TRIED A SEARCH ON GOOGLE
if you put it in several ways you might find something.. good luck
G7HEU
« Reply #7 on: March 22, 2004, 07:09:17 PM »
Gregg
I did a google search on your radio beacuse I am nosey! I noticed some references to it being used in aircraft. If that's true it might well be AM and not FM ( and therefore prob not much use on 2mtrs ).
Is there some way you can verify the modulation mode before going on a 'wild goose chase'?
In lieu of test equipment, how about using an all mode scanner and a dummy load ( I don't need to type NOT AN ANTENNA do I? )?
Hope that helps,
Steve
M0HEU / G7HEU.
