Author Topic: Grundig 700  (Read 612 times)
JBKR6C
« on: May 31, 2004, 11:00:17 AM »
For any Grundig Satellit 700 owners
Before I got real serious about DXing I purchased the 700. Great little unit, had it for about 8 years and works fine except .............. it seems to be stuck in the "LOCKED" position. The only way I can turn it on or use any of the knobs and keys is if I push the switch down to the "LIGHT" position. I've tried the "RESET", no joy.
Any ideas? Bad switch?
Also, I need a new antenna for it. Anybody sell Grundig parts. I've looked around and there doesn't seem to be much if any support for it.
thanks
VE2CU
« Reply #1 on: May 31, 2004, 11:57:59 AM »
I can't help you about the radio locking up as I use the Satellit 800 myself. As for the antenna however, you might try R.L. Drake. They service Grundig and carry parts stock as far as 10 years back, at least here in Canada.
Hope this helps.
73's,
Michel  VE2CU
