Author Topic: 6:1 balun  (Read 22531 times)
CT1FKC
« on: December 29, 2002, 10:56:07 AM »
does anyone have plans for winding a 6:1 balun with toroids. I am planing to use one with a  Windom antenna.
« Reply #1 on: December 30, 2002, 12:50:09 PM »
You didn't say what frequency or power level, but if you use a suitable ferrite material and large enough core to handle the power you run, just wind 5 turns for the secondary and 2 turns for the primary, on the same form, and you have a balun with a 6.25:1 impedance ratio (5/2, squared).  That's close enough, and what most people do, to make a "6:1 balun."
I usually use Teflon-insulated #12 gauge wire and a very large core (2" I.D.) to avoid saturation for KW-level transmitting; for lower power levels, obviously both smaller gauge wire and a smaller core will do.  The wire should be insulated with something (good enamel coating, as a minimum).  I like using stranded-conductor, Teflon-insulated wire because it's very tough and almost impossible to wear through even with long-term vibration.
WB2WIK/6
CT1FKC
« Reply #2 on: December 31, 2002, 12:22:26 PM »
thank's for the reply.
I am planning to build it for 10 20 and 40m, and for 100w power level.
I presume a T200-2 or FT200-43 work fine for that level.
I'll try it with an antenna analyzer, with a resistive load first to take some conclusions.
73 and Happy New Year.
AD6JN
« Reply #3 on: January 06, 2003, 03:56:16 PM »
Get a copy of "Building and Using Baluns and Ununs" by J. Sevick.
I recently build a 6:1 (6.24:1) series balun described in chapter 5.  It consists of a 1.56:1 Unun and a 4:1 Balun.  I used 3 toroids F140 mix 61.
1 toroid is for the 1.56 Unun and 2 are for the 4:1 balun.
For 100 watts you can use 20 and 22ga. wire.  The 1.56 unun will be 5 turns quintufilar (20ga. magnetic wire) and the two 4:1 balun coils will be 15 to 17 turns (22ga).  Use TFE on the 4:1 leads with a TFE spacer in the center of the bifilar.  You can use TFE stranded wire and strip some TFE insulation off some wire for the center TFE spacer.  Each coil of the 4:1 must be close to 150 ohms as it is in parallel at the input (75 ohms) and in series at the output (300 ohms).
When testing with the analyzer terminate the balun with a 312 ohm rersistor and plot VSWR versus Log Frequency.  The VSWR should be very flat over the range you defined.
Good luck 73.
Bob AD6JN
N6AJR
« Reply #4 on: January 16, 2003, 03:33:47 AM »
try http://www.buxcommco.com/  he has a super plan for a windom antenna there and even will sell you the 4 to 1 balun if you need it.. he also has lots of other goodies..tom N6AJR
CT1FKC
« Reply #5 on: February 01, 2003, 07:36:00 PM »
for what all you have post it seems to me that windom antenna is the best solution for me. not only because it is simple, but also because I can perform some tests with my antenna analyzer about the balun.
and since I am still recovering from a small surgery it will be easy to install.
thank you and good DX.
ZS6JMB
« Reply #6 on: January 18, 2016, 12:06:21 AM »
I know this is an ancient post, but it was exactly what I was looking for. I'm a brand new ham so bear with me if this is a dumb question
I'm wondering if a 6:1 balun should actually be wound like this with a tap, rather than WB2WIK's simple solution. It occurred to me that maybe that simple solution isn't actually a balun. I know it's a transformer and takes care of the impedance matching, but does it take care of the balanced antenna vs unbalanced coax side of things, ie does it prevent the feed from being part of the antenna? If it does take care of that, why would anyone use the complication of the tap at turn 9 of 11 as shown in the link? Is that link's autotransformer method of incorporating the primary in the secondary and having the mid-point of the secondary as the connection to the coax shield, significant?
(It would be feasible to make WB2WIK's (5:2)2 = 6.25:1 solution more precise with (22:9)2 = 6:1 but that's a  detail....)
Is WB2WIK's solution really a balun or is it only an impedance matcher?
Jim ZS6JMB
Johannesburg KG43at
UTC+2
WB2KSP
« Reply #7 on: January 18, 2016, 05:00:38 AM »
I believe you are in the wrong forum for this type of question. This forum is about antenna restrictions due to covenants and home owners association, not the design of antennas. Good luck with your search for an answer.
ZS6JMB
« Reply #8 on: January 18, 2016, 05:35:59 AM »
Fully agree, but I'm just latching onto the existing question to which mine is a supplementary. This way, the original posters might see my add-on, and respond.
But you're right: I'll post in a more suitable forum with a link to this so others can see the original suggestion.
EDIT... I've posted the same question here so any responses should rather go there. Thanks to WB2KSP for pointing out this is the wrong forum. In my defence, the thread was here already Wink
« Last Edit: January 18, 2016, 05:51:01 AM by ZS6JMB » Logged
Jim ZS6JMB
Johannesburg KG43at
UTC+2
WB2KSP
« Reply #9 on: January 18, 2016, 08:34:39 AM »
Not a problem and thank you for understanding my meaning. You as well as everyone with an opinion on the subject are always welcome to participate. You don't need to defend yourself. I just thought you'd like to post in a forum which could give you an answer to your question. Thanks again.
ZS6JMB
« Reply #10 on: January 18, 2016, 08:13:20 PM »
Nice to know, thanks.... in many forums, you DO need to....
Jim ZS6JMB
Johannesburg KG43at
UTC+2
