Author Topic: Looking for Packet software for old Apple ][  (Read 608 times)
KC1XU
« on: December 11, 2004, 03:02:58 PM »
Has anyone got software for an old Apple ][?  I'm setting up a 1980 vintage station, and would like to conect an old Apple ][ to an MFJ TNC.
Happy Holidays!
Keith
K0BG
« Reply #1 on: December 11, 2004, 03:33:58 PM »
You might try www.macusers.org and look at the archives. I sort of doubt you'll find anything, but it is worth a try. Depending on which Apple II you have, that is. The later "e" model has a better selection, but of lot of "e" software will not run on the original Apple II.
Good Luck in your search.
Alan, KØBG
www.k0bg.com
KL0S
« Reply #2 on: December 11, 2004, 04:26:38 PM »
Try:
http://www.winternet.com/~nedbalek/appleii.html
This may be what you're looking for.
Dino KL0S/4
WA9SVD
« Reply #3 on: December 11, 2004, 08:14:44 PM »
Packet-Specific software might be difficult to find, but any Terminal Emulation software will let you run packet.  (You command/control the TNC just as you would in MS-DOS mode with terminal software.)  Look for a program such as Ascii Express for Apple (there was also a version of the program for MS-DOS.)
KL7IPV
« Reply #4 on: December 19, 2004, 10:28:03 PM »
Is the apple you are using running a 6502 chip and GWBasic? Is the model an "e" or otherwise? IS the Apple running C/PM or DOS? I may have a program here if I knew what you needed specifically.
Frank
KL7IPV
respond here: sirdrakejr@aol.com
