Author Topic: TS 940 locked in transmit  (Read 743 times)
KC4GS
« on: May 10, 2004, 12:30:39 PM »
TS 940 is in transmit, with nothing hooked up but antenna and power cord.  all buttons seem to be set to off position, reset did reset memory but did not reset transmit.   Any ideas ??
Mike
WB2TQC
« Reply #1 on: May 10, 2004, 12:59:39 PM »
Just a total guess here but if it has relays you might look for a short to ground in the relay operating path.
Had it happen to me once on an Old Tempo One. I guess you could also check to see if any of the relays are stuck in the Xmit mode even without power.
K3ASF
« Reply #2 on: May 10, 2004, 01:08:25 PM »
This may sound simplistic but you might want to check the VOX switch
NU7J
« Reply #3 on: May 10, 2004, 01:22:09 PM »
Sounds like the T/R relay is stuck.  Must be something simple simple like that. If the transmit light is on and the receiver is muted, then the T/R relay is probably the culprit.  If I remember correctly, the T/R relay is near the back of the rig somewhere.  I think it may require some dis-assembly to access the relay.  You might want to post that question on the Kenwood relector for some more ideas, and/or some more specific instructions.
GL and 73,
Tom, NU7J
WG7X
« Reply #4 on: May 10, 2004, 11:09:21 PM »
Is the "SEND/REC" Button, located extreme right center of the rig, above the PHONES jack, pressed in?
Just a thought.. been there done that...
73, Gary WG7X
KC4GS
« Reply #5 on: May 09, 2005, 03:00:25 PM »
Repair shop fpund bad solder joint on back of switch panel, also bad transitor in keying circuit.  110 to fix Thanks
