Author Topic: ICOM 718 HM36 HANDMIC WIRING???  (Read 2858 times)
VE7REN
« on: November 21, 2005, 09:39:00 PM »
UUUMMMMM,WELL,I FORGOT!!can anyone tell me the color code for the plug pins for the hm36. i believe they were right-left.ground,blue,green,nothing,black,nothing,white.pin #8{center one}has nothing.i tried,and got it to key up,but no audio??? cant seem to find my manual??any help appreciated.
2E0JHA
« Reply #1 on: November 22, 2005, 01:51:44 AM »
i cant find the colour code for the wireing but pin 1 is mic input. 2 is dc output, 3 is frequency up ,down, 4 is main readout, 5 is ptt, 6 is ptt ground 7 is mic ground,and 8 is main readout af output.
VE7REN
« Reply #2 on: November 22, 2005, 04:28:29 AM »
i thought pin #2,4,8 are all left blank??
« Reply #3 on: November 22, 2005, 06:03:14 AM »
Be VERY careful wiring any Icom microphone connector, especially the modular ones.
If you short out the 8 VDC line, even for a millisecond, the 8 V regulator will fail! This is NOT a cheap fix. Further, the mic hot has 8 V on it too, albeit in series with a resistor. Nonetheless, long term shorting this lead to ground (as some microphones do by virtue of their design) will also cause the regulator to fail.
Alan, KØBG
www.k0bg.com
A9KW
« Reply #4 on: November 22, 2005, 08:49:07 AM »
Pin 1 - white
pin 2 - no connection
pin 3 - black
pin 4 - no connection
pin 5 - green
pin 6 - blue
pin 7 - shield
pin 8 - no connection
2E0JHA
« Reply #5 on: November 22, 2005, 12:17:01 PM »
 i am sorry...my manual said nothing about anything being left blank, thats untill you look at the schematic diagram
2E0JHA
« Reply #6 on: November 22, 2005, 12:17:12 PM »
VE7REN
« Reply #7 on: November 22, 2005, 04:14:09 PM »
A9KW.THANK YOU VERY MUCH.VE7REN.
A9KW
« Reply #8 on: November 22, 2005, 04:50:30 PM »
Your welcome
73s TOM
