Author Topic: Antenna Installations  (Read 705 times)
KB4IGN
« on: April 09, 2006, 04:32:59 PM »
Anyone have a good suggestion on how to get ant. cable from roof to cockpit on a Honda Accord other than thru door gasket.( no holes allowed )
KA0GKT
« Reply #1 on: April 09, 2006, 04:39:22 PM »
Through he trunk,
Through the engine compartment,
Through the floorpan (plastic drain plug)
73 DE KAØGKT/7
--Steve
W3FJ
« Reply #2 on: April 09, 2006, 04:41:07 PM »
My suggestion would be to contact someone local that does installation of mobile cell phones. If you explain what you need they can usually do it with ease and can also run power direct from the battery in a professional manner. it may cost a few dollars but it'll be done properly.
K0BG
« Reply #3 on: April 10, 2006, 06:25:54 AM »
When you limit yourself to "no holes" you also limit your threading options. I can almost guarantee you have water leaking into the cabin if you do use the door seal. The same goes for the trunk.
You didn't say what kind of antenna you were planning to use, but it sounds like a mag mount. Here's a couple of things you better know. First, most insurance companies will not cover any damages caused by a mag mount antenna. Secondly, using one will not save your paint. Read what I have to say about them on my web site.
Although you didn't ask, one responder mentioned the incoming power. This is easy on a Honda. Just to the right and just above the accelerator cable pass through, is a plugged 18 mm hole. It is easier to see from the engine side.
Alan, KØBG
www.k0bg.com
