Author Topic: Which Antenna??  (Read 118 times)
KI4HBX
« on: May 06, 2006, 09:07:00 PM »
I just bought a kenwood R-5000 reciever what would be the best antenna to purchace for this? It is my first reciever any help would be appreciated.
N3UMH
« Reply #1 on: May 06, 2006, 10:10:01 PM »
It's probably good to start simple and cheap.  I'd recommend a random wire fed against ground, honestly.
I'm with others on this site that a random wire + tuner is not a good first transmitting antenna because of RFI problems, but as a general-purpose HF receiving antenna, they're passable and easy.  You can skip the tuner for RX use.  Do a google search on "receiving random wire" and variants for details.  There are many many sites out there, many of which with pictures.
I imagine what you want is more or less all-ham-HF-band coverage?  If you have a reasonably quiet location (not lots and lots of local noise sources), you'll hear plenty of stations with a random length of wire.
OK, you didn't ask for the simplest and cheapest though...
A random wire is not the BEST antenna you could have for listening.  If you want super-duper RX performance, phased Beverage antennas or phased vertical arrays (http://w8ji.com/w8ji_rx_ants.htm), etc
etc would truly be the best for certain conditions and bands.  I'm not sure there are many turn-key solutions there.  Not simple at all, not necessarily cheap.
Small receiving loops are good for the low bands.
Simple half-wave dipoles are good all-around antennas for the higher bands.
I guess my overall recommendation is: put up some wire.  Put it up high.  Listen.
Read about other RX antennas that have better performance and when you are struggling to hear cool stuff, think about an antenna upgrade.
Dan
N3OX
2E0JHA
« Reply #2 on: May 07, 2006, 03:37:41 AM »
hello, i would suggest a random wire to start with.
Cheap and easy to construct.
A friend of mine lives in a very small property and has just started in radio listening , he has run a random length of wire around his attick space and it works fine picking vk stations up along with LW stations so he isnt doing bad.
this type of antenna will get you going in no time while you do a little research on any antenna you may purchase.
Forgive me if im trying to teach an old dog.. My advise for what its worth is read up on any antennas you have in mind, ask other hams questions and try gain knowledge on the types of antenna you want this way you can make some sort of "educated" guess as whats best for your situation..
N6AJR
« Reply #3 on: May 07, 2006, 12:13:09 PM »
http://www.ku4ay.net/dipole.html
http://www.qsl.net/kd7rem/antdipole.htm
http://www.hamuniverse.com/multidipole.html
http://www.angelfire.com/nb/ni4l/ni4ldipole.html
http://www.arrl.org/tis/info/pdf/9611073.pdf
http://www.geocities.com/n2uhc/2banddipole.html
http://www.qsl.net/na4it/fandipole.html
