Author Topic: TH-D7AG buttons won't work?  (Read 102 times)
KE3AD
« on: June 16, 2006, 08:29:58 AM »
Downloaded the software, programmed several frequencies into the machine.  Now the VFO button emits a high pitched sound, like is is disabled, and I can only get memory channels.  The menu botton does the same thing.  Any ideas?
Bill
WA4BLM
« Reply #1 on: June 16, 2006, 10:13:36 AM »
I'm guessing you're talking about the KWD Memeory Control Program for the D7.  I've used it without any problems so don't know what the problem may be.  Have you tried doing a full reset to take the D7 back to its default settings?  Turn on the D7 while holding the F key down, use the UP/DOWN button to select FULL RESET, then press OK.  Of course, you'll lose anything programmed in the D7.
Good luck,
John WA4BLM
