Author Topic: TS-930SAT S-Meter Lamp(s)  (Read 2312 times)
W4BCD
« on: May 01, 2007, 07:18:17 PM »
Both S-Meter lamps on my 930 are burned out. I read that a 12V lamp from Radio Shack would work as a replacement. I tried that and they worked for a short time but also burned out. The voltage across the leads supplying power to the lamps measures 28.8VDC with a Fluke DMM. Does this sound correct? If so, can anyone suggest a source for a
replacement lamp? Help ! ! ! Thanks
KB9CRY
« Reply #1 on: May 01, 2007, 07:40:50 PM »
Go with an LED with dropping resistor.  They'll last forever.
KC8VWM
« Reply #2 on: May 01, 2007, 08:43:09 PM »
28.8 vdc is not a "typical" voltage for meter lamps.
However, you might find a 12vdc source inside the rig and follow KB9CRY's suggestion.
In addition to lasting almost forever, using LED's to replace lamps inside your radio reduces draw on the power supply and reduces lamp heat from building up inside the radio.
73 de Charles - KC8VWM
W4DRR
« Reply #3 on: May 02, 2007, 05:52:35 AM »
Actually, 28V is a very typical lamp voltage.  Usually only in Military/Aviation equipment though.
Bob
Bob
AC5E
« Reply #4 on: May 02, 2007, 09:25:37 AM »
There are plenty of 28V bulbs around. The problem is the base! They come in miniature bayonet similar to the #47, slide in, miniature screw base, and a dizzying number of alternatives.
I could probably dig up a Chicago Miniature Lamp catalog and give you some numbers - but what sort of base do they have?
73  Pete Allen  AC5E
KA6OTJ
« Reply #5 on: May 02, 2007, 10:33:25 AM »
The 12v radio shack lights work fine.  The old number for the bulbs was rs272-1141.  What you need to do is put the 2 bulbs in series with a 640ohm half watt resister and they will out last the radio.  At least that was my experience.  Once I did that I never changed them again.
N6AJR
« Reply #6 on: May 02, 2007, 01:37:41 PM »
http://www.kenselectronics.com/lists/lites.htm
they have a ton of bulbs
