Author Topic: Kenwood st 950sd  (Read 1426 times)
VE3GCK
« on: December 19, 2007, 02:29:38 PM »
Hi I have a St950sd the RF board needs replaceing,but the sd board it discontinued part no. x44-3100-00.
 Is the board from the st 950sdx compatable the part no. being x44-3140-00
                        Thank Gary VE3 GCK
WA9SVD
« Reply #1 on: December 19, 2007, 05:27:01 PM »
You probably should ask Kenwood first; or get the Service manuals and compare part numbers.
    Kenwood Tech Service is usually very good (24-49 hours) at replying to e-mails, but hurry before they take time off before the holidays.
    you can get some of the manuals here:
http://www.radioamateur.eu/KENWOOD.html
    Good luck.
KA5IPF
« Reply #2 on: December 19, 2007, 07:03:05 PM »
A look at the service manuals shows the PC boards to be almost identical. There was a change in the RF BPF filter circuit to add additional filtering in the SDX and change the pick-off point. It appears (not guaranteed) that the SDX board would sub and work fine. Do you have either service manual?
Clif
VE3GCK
« Reply #3 on: December 25, 2007, 02:50:32 PM »
Hi Cliff I have ordered the new board for my sd ,the board i oered is for the sdx and i agree with you its verey simular I have fornd only one diffrence and that is the att 1 and att2 are reverse ill loke into to it and see if i can change that on the board thanks for your help Gary VEGCK
