Author Topic: Power SUpply  (Read 106 times)
W9DML
« on: December 29, 2007, 11:32:21 AM »
Busted Pyramid ps-26KX
Blows a 5A fuse at turn-on.
Is there  any history on this problem ?
 BTW NO LOAD
daVe
« Reply #1 on: December 29, 2007, 12:01:01 PM »
Shorted rectifier or filter cap most likely. Diode check the pass transistors while you're in there.
Should be an easy fix.
WA3SKN
« Reply #2 on: December 30, 2007, 09:50:42 AM »
Yep!
Break out the ohmmeter!  Start at the power cord, looking for shorts.  Expect either diodes or capacitors!
Good Luck!
-Mike.
W9GB
« Reply #3 on: December 31, 2007, 06:32:10 AM »
Start here for DIY
http://www.kbt-dc-supplies.com/fixem1.php
http://www.kbt-dc-supplies.com/info.php
w9gb
