Author Topic: TUNING KNOB FOR BC-455 RCVR  (Read 5599 times)
K6KSR
« on: December 06, 2000, 08:30:24 AM »
I'm in need of a tuning knob for an ARC-5 Navy receiver, BC-455. This carried a Navy part number of 6743 and fits directly on the front panel of the unit. Any help?
Thanks & 73
JD/K6KSR
N1TWY
« Reply #1 on: April 09, 2001, 09:02:06 AM »
Are you looking to use the ARC-5 or is this for show?
The real knobs for these are hen's teeth - I have exactly one and someone else will get it at the estate sale...if I don't take it with me...<grin>. However, getting something in the hole to tune the rig is not all that big of a deal.
Take a piece of plastic tubing (polyethylene, not vinyl) the OD of which will fit in the spline hole, and with an ID a bit smaller than the tuning spline. Heat the end of it in boiling water, then press it into the tuning knob hole.
Leave it there till it cools, then it should hang onto the spline and allow you to tune the receiver easily. Put a garden-variety setscrew type knob on the tubing end to dress it up a bit if you wish - I've done it both ways, and find a knob is easier to grip than the protruding end of the tubing.
Pretty it's not - but it does work.
K6KSR
« Reply #2 on: April 09, 2001, 11:31:17 PM »
A big thanks to N1TWY -- thanks Alan for the info on the homebrew knob for the BC455. And, yes, it's for actual use on the old darlin'. I shall get some tubing and give it a go! 73, John/K6KSR
