Author Topic: Hallicrafters Transmitter Model HT-40  (Read 430 times)
KA5PNE
« on: May 16, 2002, 05:20:36 PM »
What could be the single most or even combination of problem(s) that causes a vintage transmitter like this to produce "...a filtered tone, definite trace of ripple modulation..."?  Tube, Caps(s), both?  Have you experienced this problem before?  Your feedback will be gratefully appreciated.
KD7KOY
« Reply #1 on: May 18, 2002, 12:16:22 AM »
Some may disagree, but a rig that old, I would change the caps before even trying it on the air.
All my tube rigs have been recapped, if nothing else than for peace of mind and I have eliminated a potential problem. This includes filter caps.
Caps get leaky with age and some can short.
Check the resistors also while your in there. Anything out out of tolerance, change it.
You can get caps at AES.
The tubes can be checked but some tube testors only check for shorts etc.
It's not an "overnight" project, but you will learn alot about your rig in the process and in the end have a set that works as new.
I personally find it fun.
If you don't have the manual, get it. it's a "must have" item for any restoration.
Just a word of caution. High voltage is present, Dangerous. If you have not worked around the tube gear, find someone who has before you tear it apart.
Disconnect the unit and discharge any caps before working on it.
Good luck.
W9GB
« Reply #2 on: May 19, 2002, 10:26:40 AM »
The HT-40 was my Novice trasnmitter in the earlier 1970's
I would agree with the comment of replacing the paper and electrolytic capacitors (Orange Drops work well for the paper replacements) .. heat probably has dried out the elctrolytics
The other issue you have to watch for on this model is the mode switch on lower left corner.  Look for arcing or dirty contacts (that problem confounded me for a few days)
w9gb
