Author Topic: Cantenna oil  (Read 876 times)
W8JI
« Reply #15 on: August 09, 2008, 08:13:25 PM »
Ant urine works fine. It just takes a while to fill the can up.
W6VPS
« Reply #16 on: August 09, 2008, 10:27:01 PM »
Ant urine...is that sorta like changing the oil in your cow ?
Boo Charles...Boo !!!
But funny none the less..
73 /  Paul-W6VPS
« Reply #17 on: August 11, 2008, 06:12:54 AM »
Brake fluid may work as well.  I have a smaller homebrew cantenna, (one quart size) and I used brake fluid in it.  Made it a few years ago and opened it up to check it when I read this thread.  Everything looks OK and it still works OK.
W8ATA
« Reply #18 on: August 11, 2008, 06:32:30 AM »
Well a while back I did try W8JI's suggestion for fresh goat testicles on a J pole and that worked. So now I'll try the ant urine. Slow collection for sure, but an ant diuretic will speed it up. Any suggestions for one?
Russ
WA3SKN
« Reply #19 on: August 11, 2008, 07:26:00 AM »
You can use just about any oil at HF.  And, you will probably want a better dummy load than the "Cantenna" at VHF and above anyway! There are lots of surplus VHF+ dummy loads available on the market nowadays.
73s.
-Mike.
W3LK
« Reply #20 on: August 11, 2008, 10:29:54 AM »
If you go for the ant urine, you need to invest in a couple of ant farms and not depend upon a single ant!
Lon - W3LK
Naugatuck, Connecticut
WA9SVD
« Reply #21 on: August 12, 2008, 07:13:30 AM »
Local vet supply;
    Otherwise, 99 Cent stores, Dollar Tree, etc. usually have pint bottles.  That adds up to $8.00, not $48.00 for a gallon.
KE5HLS
« Reply #22 on: August 19, 2008, 06:55:20 PM »
Ok, so tell me if I've been mis-advised. I got a Cantenna 2nd hand some time ago & needed oil. After having a little trouble locating transformer oil for a good price, someone suggested vegetable oil.
I found this readily available  cheap at WalMart, & etc.
I bought a gallon for about $5 & have been using it for about a year or so now. I have driven up to full legal ( although not for very long ) HF.
Any reasons I should know that this is a bad idea?
Thanks
