Author Topic: Bird Wattmeter/Dummy Load shorted shunt coil  (Read 728 times)
K4JJL
« Reply #15 on: October 30, 2006, 09:28:53 AM »
Response from Bird:
Good morning Jared,
Unfortunately this unit has been obsolete for a number of years. There are only a limited number of prints available and the print that shows the value of that shunt is no longer available.  I am sorry I am unable to help you with this.
I unsoldered and unwound the wire from the coil and measured its length.  I'm going to try to rewind a new one w/ the same size wire.
When I unwound it, I discovered that it was toasted inside, shorting several windings together.
VE3ZXK
« Reply #16 on: January 11, 2009, 10:18:48 AM »
Ok,
time to clear all the confusion boys,
I have the same meter, I am missing the shunt totally.
The TS-118A uses external precision thermocouples to measure power, between 5 and 500W, the shunt protects the transmitter, and with some engineering, the value of the coil can be learned. This is a simple project, as it lies outside the meter.
VE3ZXK
« Reply #17 on: January 18, 2009, 07:50:26 PM »
Ok,
I have built my own shunt, it is working now. I used a 4uH coil built into a very small enclosure. VSWR is good.
AF7U
« Reply #18 on: February 16, 2013, 03:49:29 PM »
Interesting... Bird, in their manual calls it a 'Thermocouple'...  Hmmmm...
