Author Topic: ts 570s multi/ch button  (Read 549 times)
KP2BH
« on: June 29, 2008, 04:21:19 AM »
hi
iown a ts570s and the multi ch button is acting crazy.for example if i adjusting the power its jumps from 50 to 10 and if i keep turning the number get from one to the other,same with the other funtions that involve that button. do any one who own a ts 570 had the same problem?
jimmy
KC0FFC
« Reply #1 on: June 29, 2008, 06:28:04 AM »
Yes, it is a known problem.  Check the ts570 yahoo group for past postings.  The part can not be cleaned, only replaced.
Paul, 73
W3LK
« Reply #2 on: June 29, 2008, 06:29:35 AM »
I have the same problem and I'm too lazy to get the encoder changed out.
Lon - W3LK
Naugatuck, Connecticut
K0RFD
« Reply #3 on: June 29, 2008, 12:47:14 PM »
I have successfully cleaned mine by blowing down the shaft with compressed air.  Not the kind that comes in a can, but 80 psi air from a compressor.  It works sometimes, in fact more often than not if you keep trying until it works.  I need to do this about every 6 months.  Just went through Field Day and it didn't skip once.
W3LK
« Reply #4 on: June 29, 2008, 03:29:36 PM »
Interesting, just blew it down the shaft?
I'll have to give that a try.  Did you rotate the shaft at the same time?
Lon - W3LK
K0RFD
« Reply #5 on: June 29, 2008, 05:30:37 PM »
Yep.
Of course, it depends on WHY it doesn't work, what's dirty about it, but nothing ventured, nothing gained.
W3LK
« Reply #6 on: June 29, 2008, 06:33:37 PM »
That's my thought.
Thanks for the tip.
Lon - W3LK
KE4DRN
« Reply #7 on: June 30, 2008, 05:05:11 PM »
hi,
W02-1901-05       ELECTRIC CIRCUIT MODULE TS-570D
from kenwoodparts.com or pacparts.com
$ 11.00 as of today plus s/h.
Easy to repair, be sure to use solder wick
and a liquid flux pen when you solder the
new part.
73 james
W3LK
« Reply #8 on: June 30, 2008, 06:41:21 PM »
James:
Thanks for that information.
Lon - W3LK
KP2BH
« Reply #9 on: July 01, 2008, 11:28:41 AM »
Thanks to all who respond to my post,specially james KE4DRN for the part info.i just order it.thanks to all.
KP2BH
jimmy
LA7DFA
« Reply #10 on: May 09, 2009, 09:39:24 AM »
You can fix the problem by using a power drill.  Connect it to the shaft of the MULTI/CH and spin it for a while.
I did this to my TS-2000 and it works perfect now.
W3LK
« Reply #11 on: May 10, 2009, 06:15:57 AM »
April 1st is long past.
There's no way I would do that; it is a good way to destroy the shaft and whatever bearing is in there.
Lon - W3LK
W3LK
« Reply #12 on: May 10, 2009, 11:17:31 AM »
As well as the encoder, itself.
Lon - W3LK
KD5CKP
« Reply #13 on: November 06, 2012, 04:42:00 AM »
FWIW...
I didn't try the drill idea, but I did sit here using just my fingers and whirled it around quickly in both directions for a couple of minutes and the issue is gone....for now.
NO2A
« Reply #14 on: November 06, 2012, 07:50:52 AM »
Simply turning it slowly usually works for me,with any radio with a multifunction encoder.
