Author Topic: Wilson WR-500 antenna rotor  (Read 9352 times)
KA5ROW
« on: September 20, 2007, 10:27:40 AM »
Does anyone know the wind load rating of the Wilson  WR-500 antenna rotor. I can not find any useful information on the net.
WA3SKN
« Reply #1 on: September 20, 2007, 11:31:14 AM »
I THINK that Wilson put their name on the Allied HD-73 rotor, but this is coming from "way back" in the memory cells.  I could be mistaken!
-Mike.
KB4QAA
« Reply #2 on: September 21, 2007, 07:06:20 AM »
W7FG has the manual for $5.  Cheap!
http://www.w7fg.com/search.php?find=500
Can't find anything else for you.  Good luck.
Bill
W6VPS
« Reply #3 on: September 21, 2007, 08:55:08 PM »
Contact me at the email add. listed on QRZ. I can send you a PDF copy of the HD-73 manual
Paul/W6VPS
W9GB
« Reply #4 on: September 23, 2007, 07:23:33 AM »
This answer was provided by Chuck, N4NM to an identical question posted by Kurt Andress, K7NV on behlf of another amateur -
Tower Talk on contesting.com Sunday, 1 August, 1999
From the WR-500 manual:
    Max. Load:          6 sq. ft. windload
    Motor torque:       780 inch-pounds (stall torque)
    Brake type:          Disk
    Brake torque:       1300 inch-pounds
    Gears:                 Stainless
    Bearings:            96 ball bearings; 750 pounds balanced weight capacity
There's more, but that's most of the important stuff. Be wary of wind load specs ... I would pay more attention to the torques, and compare these with modern rotators which also give things like "K-factors" just so you can compare "apples with apples".
If you want anything specific, or a copy, let me know.
The manual has a good schematic, too. This thing bears a striking resemblance to the current Yaesu family of rotators.
If I remember correctly, I tried the rotor side connector with my G-800 cable, and found that it mated. The control box, however, is totally different.  DO NOT try to mix & match!
The Wilson rotator uses an A.C. motor, while the Yaesu series uses D.C. motors.
Chuck, N4NM
N8ZHC
« Reply #5 on: May 16, 2009, 09:03:40 AM »
Hi
Doe's any one know where i can find the Potentiometer assembly For the Wilson wr-500 Rotor? I think it's 100 ohms? If It's the same rotor as the Alliance HD-73-1 The part number is (19486-R)
N8ZHC
W6VPS
« Reply #6 on: May 17, 2009, 10:50:47 PM »
Norm's Rotor Service
N8ZHC
« Reply #7 on: May 18, 2009, 08:42:10 PM »
Hi
do you no Norm's rotor service e-mail address?
Allan
N8ZHC
« Reply #8 on: May 22, 2009, 09:08:34 PM »
Hi
wrote to Norm's rotor service. They don't have any parts for Wilson rotors
N8ZHC
K9FON
« Reply #9 on: May 23, 2009, 12:48:34 PM »
Wilson rotors are VERY VERY hard to find parts for. The rotators are their own kind and Wilson didn't copy any other companys design. I myself, have never seen one at any hamfests or on Ebay.
UN8GEQ
« Reply #10 on: June 19, 2013, 07:49:06 PM »
I bought this rotor on ebay as it once long ago ... The rotor is in a satisfactory condition, lubrication required, and the control unit was broken direction indicator (arrow). I bought a Chinese "no name" indicator, suitable in size, changed the scale and everything works.
Using a rotor on a low mast, the thrust bearing is, rotating them homemade squares (2 ele.) on the CB, and 50 MHz. And also - VHF / UHF (4/7 elements). No Problems. Tongue
