Author Topic: Atlas repair  (Read 293 times)
K9FON
« on: September 05, 2009, 04:10:32 PM »
Does anyone know a good Atlas tech? I have a 210X that needs a tune up.
K0BG
« Reply #1 on: September 05, 2009, 05:59:11 PM »
All you need is a good service monitor (stable signal generator), a hex tool, a schematic, and about 30 minutes of your time. It's simple, and straight forward. The only tough part, is getting the band pass centered. Fact is, you can get fairly close with just the marker and the S meter.
Alan, KØBG
www.k0bg.com
« Reply #2 on: September 05, 2009, 06:02:57 PM »
What are the symptoms?
K9FON
« Reply #3 on: September 05, 2009, 07:33:08 PM »
Well the easy parts is done. I gave it a tune up tonight. It was transmitting but now its dead. The finals look ok but i found a resistor that is blown. I will dig into it more tomorrow.
9A5BDP
« Reply #4 on: September 06, 2009, 12:25:57 AM »
I have also one Atlas 210X that needs adjustments. Please tell procedure steps for proper way of adjustment. I rebuild power amplifier board after last owner burrnigout. PA stage works now fine but sensitivity of receiver is poor.
Thanx in advance...
K0BG
« Reply #5 on: September 06, 2009, 05:23:57 AM »
As I said above, it's about as simple as they come. You can get very close by just using the calibrator, the S meter, and a good ear. If you have a stable RF generator (service monitor?), it takes almost as much time removing the covers as it does to tweak the coils and caps.
Alan, KØBG
www.k0bg.com
N5YPJ
« Reply #6 on: September 06, 2009, 12:14:03 PM »
Mel at Kcomm in San Antonio (tel. (210)344-3311 ) did a great job on my Atlas 210x.
If you do go with a tech beware that you can easily spend more repairing the old rig than it's worth and you still have an old radio.
K9FON
« Reply #7 on: September 07, 2009, 09:12:33 AM »
Id like to try to fix it myself.
I think i found the problem. I HOPE!
I found what looks like a resistor that was blown open. However i cant identify it.
It is black and looks like a football with two leads coming out of the bottom. The top of the resisitior is green with a tiny black letter "C" and the color bands starting below the green are brown (gold perhaps?) green and blue.
WD5GWY
« Reply #8 on: September 07, 2009, 06:03:07 PM »
Here's a link to a webpage that has a lot of good
info on the Atlas 210X and 215X. You will find
schematics and other useful info there.
Good luck.
james
WD5GWY
http://www.qsl.net/on6ab/Atlas.html
K4DPK
« Reply #9 on: September 07, 2009, 06:21:43 PM »
OK…It needed a tune-up, so you tuned it up.
Then it stopped transmitting.
What guidelines did you use to tune it up?
Now you’ve found a part “blown open”?
I can tell you for certain, if a resistor (or whatever) fails catastrophically and “blows open”, there’s more wrong than just that resistor.  Something else caused the blow-out.
Can you read a schematic?  Can you identify the part and tell us in what part of which circuit it is used?
Phil C. Sr.
k4dpk
K9FON
« Reply #10 on: September 07, 2009, 06:41:56 PM »
I gave it a tune up to improve the receiver.
I did nothing to the TX part. If i could find a way to insert a pic on here i would. It is much easier to do that than describe the problem than try to explain it on here.
Maybe one of you guys can email me and help me out that way.
k9fon@mchsi.com
