Author Topic: Home outlets buzz when transmitting  (Read 4937 times)
K1KIK
« on: September 07, 2009, 09:51:44 AM »
Any ideas as to what might cause an electrical outlet on the other side of the house to buzz/vibrate when I transmit?  I am transmitting at 100 watts through a multi-band dipole mounted in the attic. Thanks.
N3OX
« Reply #1 on: September 07, 2009, 10:01:14 AM »
I'd check the wiring and box on that outlet ASAP, because an ordinary electrical outlet should be a completely linear device incapable of turning any applied RF into sound.  Something like a GFCI on the verge of tripping would make more sense.
With an ordinary outlet, I think you'd have to have a loose connection or RF arcing of some kind, both of which need immediate attention.
One thing that comes to mind is if you happened to have a resonant length of wire, the ground wire could be arcing to the box or something, just because the ends were at high RF potential.
What's the whole story?  What kind of outlet?  What's plugged in to the outlet?  Anything?
Dan
Dan
http://www.n3ox.net
« Reply #2 on: September 07, 2009, 10:04:04 AM »
I would guess that its a ground fault type (GFCI) in a bathroom or kitchen and that RF is being picked up by the wiring and conducted into the electronics in the GFCI. You **might** be able to replace the CFCI outlet with one of a better type. The only other solutions are to move the antenna or reduce the power output.
W4VR
« Reply #3 on: September 07, 2009, 10:45:33 AM »
The solution to this problem is to mount your antenna outside and away from your house.  If you live in a neighborhood with restrictive covenants, ask for permission to install a flagpole in your backyard.  Use small gauge wire that your neighbors won't see and pass your coax up the flagpole.
N7ZM
« Reply #4 on: September 07, 2009, 11:17:05 AM »
I had the same happen here because of inadequate grounding. It was a GFCI on the verge of tripping because if RFI getting into wiring. Fixed the grounding at my outside breaker box and the problem went away. The GFCI was located in my laundry room and the buzzing sounds were only on 80 meters when I ran my Alpha.
K1KIK
« Reply #5 on: September 07, 2009, 01:57:49 PM »
Well, my buzzing outlet IS a GFCI outlet, so I guess that I will begin by checking my grounding.  My HOA won't even allow a flagpole in the back yard. Thanks for the replies.
K8AC
« Reply #6 on: September 07, 2009, 01:58:34 PM »
If your home was built in the 1970s when they were using aluminum wire, the problem is likely a loose oxidized connection between the wire and the outlet screw.  The screw may have been tight when the outlet was installed, but the aluminum wire tended to "relax" over time, leading to a slightly loose screw and oxidation on the aluminum conductor.  Quite a few houses in this part of NC went up in smoke during the 20 years after they were built with aluminum wire.  I recall tightening up quite a few outlet screws at neighbors houses back in the mid 1970s, when the outlets were making noises as you describe.
« Reply #7 on: September 07, 2009, 02:09:03 PM »
Older GFCIs were more sensitive to false tripping than the newer ones. You may find that simply replacing the GFCI with an upgraded unit will solve the problem.
K7STO
« Reply #8 on: September 07, 2009, 02:16:43 PM »
You could start first by replace the old GFCI with a new one. The current generation of GFCI's are less prone to RF interfence and I would second the idea of relocating your antenna outside.
Mike
KB7STO
K7RNV
« Reply #9 on: September 07, 2009, 04:50:18 PM »
Hello from Reno Nv.. I had the same problem, with gfi and regular plugs, the new house i live in was done with very poor quality plugs, I replaced all plugs and gfi plugs with top quality ones and on the gfi ones i put a terrord snap on coil on the hot side and my problem is gone gone gone....It took awaile to pin it down, but when i tried and replaced the bad junk i think the builder got 100 of them for 1 buck each hi hi.. good luck..73 bob K7RNV
N5LRZ
« Reply #10 on: September 07, 2009, 06:27:14 PM »
Re CPE...
re your post..." I am transmitting at 100 watts through a multi-band dipole mounted in the attic. Thanks. "
Your electrical wires are running in your attic.
Your antenna is in your attic.
Your antenna is quite easily within close proximity to the electrical wires thus inserting your radio signal into the electrical wires.  And probably, every buzz and click from every appliance in your house is getting into your antenna.
Solution dont use an attic antenna
K7RNV
« Reply #11 on: September 07, 2009, 10:41:10 PM »
Try a screwdriver antenna mine works great and i have it hide with plants..........
K1KIK
« Reply #12 on: September 08, 2009, 02:10:29 AM »
OK.  I'll see about replacing the GFCI outlets and look into some type of "stealth" antenna.
« Reply #13 on: September 08, 2009, 06:29:17 AM »
The GFI outlet you need is made by Bryant. Google Bryant GFI RFI.
I replaced my buzzing GFI outlets with this and fixed the problem.
W8JI
« Reply #14 on: September 08, 2009, 07:42:53 AM »
The problem you have are the GFI outlets are sensitive to RF.
It is NOT a grounding problem. There is no reason at all to even need an RF ground in the house. A lightning and safety ground at the cable entrance is needed, but RF in the house virtually always comes from the antenna system.
Since your antenna is in the attic, that is how RF is getting into the wiring. The fact it is inside the attic isn't even the real issue. It is just too close to the wires. If it was outside the wall, but the same distance away, you would have the same problem.
Change the outlets or move the antenna a much larger physical distance away from the house wiring.
73 Tom
