Author Topic: ADVISE FOR A BEGINNER: DISASTER COMMUNICATIONS  (Read 533 times)
OLDGI
« on: June 13, 2006, 10:48:31 AM »
I'm an x-GI and former investigator who has always been prepared.
I'm now concentrating on implimenting a basic disaster communications system.
I'd like advise on mfg. & model of entry level pro stuff possibly with an idea of what to look for in used equipment.
One vehicle mounted radio and two hand helds.
Thanks in advance,
Walter
KC0SHZ
« Reply #1 on: June 13, 2006, 11:40:06 AM »
1.  Get a tech license for Amateur radio.  GMRS isn't as good as VHF, and FMRS is not as good as GMRS.  Besides, if you are going to drop the cash for two HT's and a mobile, then $14 for the license is nothing.
2.  Mobile:  I like my Yaesu FT-8800R.  Others like the Kenwood D400 as it has a built in TNC which can transmit your location via APRS.
Most important is to get involved with your local group (Skywarn, ARES, RACES).  Buy a radio that is commonly used around your town.  That way when some feature comes up that you don't know how to adjust, there is a greater chance that someone around town can help you.   Also, if you are helping in an event, you will be more familiar with their gear.
Next piece of advice, get involved in local radio events (charity bike rides, runs, walks, etc).  More practice working in networks has never hurt anyone.
Last piece of advice is something I saw (and used) at my first event.  Get a gadget box (little clear plastic divided tray and lid from a bead section in a craft store works great).  Get a SMA to BNC adapter, a BNC barrel, a BNC to PL259 adapter, a PL259 barrel, a type N connector to use Cable TV coax if you have to, a crimp on Coax adapter or two, some fuses, a couple of ARES standard Anderson Powerpoles, and what ever other adapters you fancy and keep them with your Go Kit.   With these you can adapt your stuff to the ambient antennas and other devices that may be around.
KE4SKY
« Reply #2 on: June 13, 2006, 12:50:05 PM »
You didn't indicate where you were or if you has an amateur license or not.  The folowing URL gives a good overview on preparedness, including equipment, but doesn't make specific brand or model recommendations.
http://www.w4ava.org/arcoRACES04.pdf
If you have a Technician license, I'd suggest an all-mode 2-meter mobile, such as the Kenwood TM255A.  This rig is discontinued, but was and is still a fine rig and will do CW, SSB, FM and digital.  Features and operation are very similar to the TS-50 HF rig which it resembles.
If you have a General license and would like one radio which does just about all of it, the ICOM 706 Mk. IIG is a good choice.
As for handhelds, older models which give great service are the Standard Model C228A and C558A dual banders.  Yaesu-Vertex doen't fix them anymore, but there are people who do.  They are reliable, commercial grade rigs.  Any handhelds used for emergency use should be able to use common AA or be able to connect to an external battery.  If you read some of the older forum archives there is alot of discussion on equipment recommendations which should help you without having to repeat it here.
W0IPL
« Reply #3 on: June 13, 2006, 03:29:01 PM »
As an ex-GI then you probably have some training (possibly a lot). http://www.w0ipl.com/ECom/EComIntro.pdf is an easy starter which should take about five to ten minutes to read.
Next would be either the ARRL's ARECC Level I or http://www.w0ipl.com/ECom/EComBas.pdf which has an ICS overview included.
Next would be the ARRL's ARECC Level II or http://www.w0ipl.com/ECom/EComNCS.pdf
Then ICS 100, 200 and 700.
Once you catch your breath, have fun!
Pat
N6PEH
« Reply #4 on: June 14, 2006, 05:06:58 PM »
Get licensed, you'll really be glad you did.
Get a dual band for the mobile and handhelds.  They are all pretty good.  If you're like most, you'll replace them all with different ones anyway sooner or later.
Before you invest too much time and money going to classes, attend some local EmmComm meetings.  Find out what they do.  If they've worked any disasters, try to get someone to fill you in on what they did to help.  They like to speak in general terms so dig for specific info.  If they do events, go to one and hang out with someone to see what's going on.
If you have access to any of your local fire/rescue/police organizations, ask them how amateur radion fits in with their protocol during a crisis.
OLDGI
« Reply #5 on: June 15, 2006, 07:06:57 AM »
I’d like to thank those of you who graciously responded to my post requesting information. I received top flight recommendations and direction. I appreciate it very much.You guys are really apart from the rest.
My sincere thanks to:
KCOSHZ
KE4SKY
WOIPL
N6PEH
K2GW
« Reply #6 on: June 16, 2006, 10:24:07 AM »
Good advice all around.  Here's the link to basic info on getting a ham radio license if you don't have one yet:
http://www.hello-radio.org/
Gary, K2GW
