Author Topic: Signal Generator  (Read 1242 times)
KD8CKD
« on: February 15, 2006, 09:08:31 AM »
I'm pretty new to HAM radio and I have a question that may be ridiculously simple but I need help nonetheless. I need to send out a constant signal using a HAM radio. I'd like to send out the signal for 10 seconds every 60 seconds. How would I go about doing this? This is a backup means of finding an airborne payload with directional antennas.
« Reply #1 on: February 15, 2006, 12:13:30 PM »
There are some transmitters built specifically for this
purpose, often used in tracking payloads in balloons and
model rockets.
http://www.bigredbee.com/beeline.htm
http://www.silcom.com/~pelican2/PicoDopp/MICROHUNT.htm
or this:
http://www.rain.org/~marvin/microhnt.htm
You can use the PICCON controller with any transmitter to
provide keying and ID:
http://www.qsl.net/n6bg/piccon/
For a small, low-powered 2m transmitter with crystal control
try this:
http://home.att.net/~jleggio/projects/rdf/40mw_tx.htm
or:
http://home.att.net/~jleggio/projects/rdf/750mw_tx.htm
A frequency-agile transmitter paired with the Montreal
Controler (as well as the controller itself) is here:
http://www.qsl.net/ve2emm/pic-projects/mt525fox/mfx525-e.html
You can build your own transmitter quite easily:  I've
used a scanner crystal on the 9th overtone, but now you
can get some pre-programmed crystal oscillators from
Digi-Key or Mouser for $6 or so.  For example (just
because I had an old catalog handy) the Epson SG8002
series will only go up to 125 MHz, but you can order one
at 1/3 or 1/5 of the desired output frequency and extract
the desired output with a tuned circuit. Add an extra
stage of amplification if needed.  You will need some
sort of controller for this, but the PICCON or Montreal
controllers will key it in CW.
For other ideas, try here:
http://www.rain.org/~marvin/equip.htm
http://members.aol.com/homingin/links.html
KD8CKD
« Reply #2 on: February 15, 2006, 01:53:39 PM »
Thanks A LOT, this is exactly the information I needed!
John
