Author Topic: 70cm RDF Beacon  (Read 4387 times)
K7RKT
« on: May 27, 2005, 10:00:42 AM »
This beacon my be interesting to the FoxHunting community.
Although it was designed to track rockets, no reason it couldn't be used for foxhunts! It's small, relatively inexpensive, and would last for DAYS on a 9V battery.  The frequency, output power and call sign string are completely user programmable.
http://www.bigredbee.com/beeline,htm
-- Greg
K7RKT
« Reply #1 on: July 10, 2005, 10:02:00 PM »
ooops, that should be:
http://www.bigredbee.com/beeline.htm
K3DC
« Reply #2 on: January 02, 2008, 06:00:14 PM »
I booked marked that one.  I want to do 70m RDF so I can use a smaller antenna than for 2m.  I would like the experience of building a transmitter from a kit.  Anyone have any pointers to one.
If I use the beeline it seems all I need is the $59 transmitter.
K7RKT
« Reply #3 on: January 03, 2008, 07:36:02 AM »
I don't offer these as kits -- getting all of the little SMD parts taped to a piece of paper is almost as much work, if not more, than putting together a complete unit.  Then there's the whole calibration issue....
Yes, the $59 transmitter is all you need to get on the air for 70cm. You'll need to supply your own battery and a TTL level converter if you wish to modify the TX parameters.
On a related note, I will soon be making available a 2 meter APRS transmitter that integrates a GPS, 1200 baud APRS modem, frequency agile FM radio, and 1 to 4 watt RF amplifier -- all integrated onto a single board.
www.bigredbee.com
Greg K7RKT
K7RKT
« Reply #4 on: January 24, 2010, 08:38:13 AM »
I have just released the BeeLine MP Transmitter
The BeeLine MP is a 150mw version of the original 70cm BeeLine transmitter.
Peak output power is close to 200 mw with a fully charged battery, and drops off
to a low of 150mw as the battery discharges to it's lower operating point at 3.2
volts.
At just 2.5" x .8", it's slightly narrower and about 3/10" longer than the
original.
Programming software, batteries, and interface hardware are all compatible.
www.bigredbee.com
-- Greg K7RKT
