Author Topic: Computer to rig interface connection question  (Read 280 times)
KU4UV
« on: November 23, 2007, 08:30:59 PM »
I don't know if this is the correct forum for this question, so excuse me if it isn't.  I have a question about adding a microphone connector to a interface cable that I constructed from plans I found on the Internet.  I have an interface that I built a couple of years ago that uses a Radio Shack isolation transformer to seperate the transceiver from the computer.  One end of the interface connects to the soundcard output of the computer.  The other connection plugs into the microphone connector on the front of the radio.  I use this interface for digital modes such as PSK31 and RTTY.  I have a TS-130SE transceiver, and I use the transceiver's VOX circuit to key the rig.
     What I am wanting to do is simply add a 4-pin mic connector to this interface so that I can also use my microphone without having to unplug the interfacfe cable.  I am wondering if it is o.k. to just go ahead and wire up a 4-pin mic connector to the femal connector that plugs into the transceiver, and then just plug my mic into this connector without it having any problems?  This is similar to what the Rigblaster interaces have, in that there is a microphone connection on the front of the interface, and then a microphone output connector that plugs directly into the transceiver.  It seems to me that thiswould fine, but I thought I should check first.  Can anyone give me any tips or advise as to whether it is o.k. to do this?  I have so far not had any issues with RF getting back into the laptop, but then I only run about 30 Watts on the digital modes, and never more than 100 Watts.  I have a voice keyer program that I am wanting to use, and I want to be able to use my microphone also for anser any CQ replies.  Thanks for the help!
Michael KU4UV
VK2ACM
« Reply #1 on: December 03, 2007, 03:44:31 AM »
Hi Michael,
You might want to try some of these programs they work pretty good, Good luck...Clint vk2acm
http://www.dxzone.com/catalog/Software/Voice_tools/
VK2ACM
« Reply #2 on: December 03, 2007, 03:47:35 AM »
Michael,
You might want to try and install a switch to switch between the interface and your microphone, This would save you disconnecting the interface. The switch would only have to be on the audio line between devices.
