Author Topic: PVC pipe antenna  (Read 2664 times)
KC9LKW
« on: July 15, 2008, 01:26:44 PM »
I thought some where i read you can build a antenna out of PVC pipe. Can this be done, or am i remembering wrong? I do have a bad memory ( At 39 ), hate to think about my memory at 75.
W3LK
« Reply #1 on: July 15, 2008, 01:40:04 PM »
There are plans all over the place for antennas that use PVC as the _support_structure_.
Since PVC is non-conductive, you can't make an antenna out of just the PVC.
Lon - W3LK
Naugatuck, Connecticut
« Reply #2 on: July 15, 2008, 04:23:26 PM »
I use PVC pipe a lot for antennas.  For example:
- as boom for VHF/UHF yagis
- as a support frame for VHF quads
- as a housing for various types of verticals
- for winding loading coils (though not always optimum)
But generally speaking it forms just the mechanical support
for the antenna, not the antenna itself.
W5FYI
« Reply #3 on: July 15, 2008, 06:35:13 PM »
You can wind a helical antenna on PVC for 80 and 160 meters or higher; or use PVC as a support structure (e.g. for quad antennas and yagis); and one guy recently reported making QSOs with a PVC pipe filled with salt water. What did you have in mind?
WD6S
« Reply #4 on: July 16, 2008, 03:18:11 PM »
15 years ago I got a plan for a 2M J-pole that used PVC pipe and two pieces of hardware cloth (the galvanized stuff with 1/4 inch mesh). It worked pretty well, but I cannot begin to remember where I found it, but I suspect it was in a magazine, probably QST. I used the grey electrical conduit rather than the irrigation pipe
Bob
KC9LKW
« Reply #5 on: July 17, 2008, 10:43:18 AM »
Thanks for all the info, it was a help.
