Author Topic: Moxon Antenna?  (Read 1242 times)
KC9KEP
« on: August 28, 2009, 06:41:48 PM »
Has anyone built the Moxon antenna that was recently
featured in ARRL/QST magazine?
It's rather rectangluar with about a 6' radius swing
for 10m if I recall.
It looks interesting, but I was wondering if anyone
had built such an antenna.
KC9KEP
N3OX
« Reply #1 on: August 28, 2009, 07:41:38 PM »
I've got two Moxons, one for 6m:
http://www.n3ox.net/projects/sixmoxon
and one for 20m, with some add-on circuitry for 17m:
http://www.n3ox.net/projects/2017moxon
Bunch of other builders here:
http://www.moxonantennaproject.com
I built mine very carefully, trying to get the measurements really close and both of them worked right away with low SWR and good F/B ratio.
I don't quite get 30dB F/B on the 6m one in actual measurements, but I get a healthy 22dB or so:
http://n3ox.net/files/mox_compare.jpg
The measured pattern is a bit ripply because of tropospheric variation on the ham who was acting as my signal source, and something took a big bite out of my pattern that I don't quite understand. ;-)
But it's workin...
Dan
Dan
http://www.n3ox.net
KE4DRN
« Reply #2 on: August 28, 2009, 07:57:18 PM »
Hi,
I also have a few, 2m, 6m and 20m
direct fed with 50ohm coax, no matching needed.
73 james
N2RRA
« Reply #3 on: August 30, 2009, 05:02:10 PM »
Here Here!
I built many of these Moxons and I Love them!
Built them for 2m, 6m, 10m, 40m and built a tri-band 10,15 and 20 meter. Their easy, inexpensive, and have the best Front-to-back performance than all yagi\'s and log periodic. If you consider expense think about how munch you can save by buying a 500 ft. spool of 12-14 awg. wire from home depot and save yourself hundreds of dollars. Weight savings is a huge factor when worrying about structural support and strain on your rotor. Less wind load is a big factor.
Depending on the band they do have limitations like number of elements per band, but they offer a space savings way of getting on the air and obtaining the same forward gain. Generally tri-band yagis comprise of a 2el per band like a 6el tribander. Same amount of forward gain but better front-to-back plus all of the above.
Big major advantage is broad band width without sacrificing forward gain or front-to-back gain unlike yagis.
Think about practicality building a Moxon as supposed to buying a full sized tri-band yagi or mono-band beam and it should make some sense. Yes! you can stack other antennas above it like yagis and not worry.
The whole point of this hobby is too experiment and see for yourself the difference between each of them. Step back and look at your hard work mysteriously out performing other antennas by working Japan, Yemen, Australia and say "it was possible to work them because I built that antenna". Build it and take pride when you tell that DX station the reason you have a 5/9+ 30 over signal is due to your home brew yagi, quad, loop, delta loop, G5RV or of course better yet MOXON.
73\'s!
KC9KEP
« Reply #4 on: September 01, 2009, 10:55:42 AM »
One more Moxon antenna question ..
It appears that these antennas are relatively
light.
Do you suppose that one could use a conventional
television type tripod, mast and rotator with the antenna?
thx!
KC9KEP
« Reply #5 on: September 01, 2009, 10:57:03 AM »
It depends - are you building the antenna for 2m or 80m?
KE7ORS
« Reply #6 on: September 05, 2009, 08:49:31 AM »
I built one for 20 meters a month or so ago and love it. It is mounted at about 30 feet above the ground and rotated with a Radio Shack TV antenna rotator. Not expensive. I am very impressed with the performance so far. It has been getting into just about everywhere I point it except for Africa. Hopefully that will improve as the solar cycle advances.
Go for it. It is a cheap antenna and works very well.
Tracy KE7ORS
KC9KEP
« Reply #7 on: September 10, 2009, 07:20:01 AM »
Thanks all!
I would probably be building a Moxon for 20 meters.
An 80 meter version would be quite large (about 102 feet!)
Now, can anyone tell me if it would be feasable
to use a 20 meter Moxon antenna for 10 meters as well?
Thanks again!
KC9KEP
KE4DRN
« Reply #8 on: September 10, 2009, 05:21:30 PM »
Hi Tom,
please join www.cebik.com
you'll need a free login and password,
it keeps out the mass downloaders.
The late Dr. Cebik, W4RNL, has a wealth
of information on Moxon designs, nesting them,
as well as many other antenna designs along
with NEC plots.
Enjoy your Moxon !
73 james
N3OX
« Reply #9 on: September 12, 2009, 03:52:01 PM »
"Now, can anyone tell me if it would be feasable
to use a 20 meter Moxon antenna for 10 meters as well? "
Hm... not directly, and I don't think even indirectly.
You can make it work pretty well on 20/17/15 with switched-in capacitors in the reflector and switched matching networks at the feedpoint...  I checked that in EZNEC when I was designing the one I use now.
I don't remember if I tried to get it to work on 12 and 10, but it gets more difficult the more different the frequency is from the natural design frequency.
You could probably successfully build a 10m Moxon on the same spreaders you use for the 20m Moxon (if you do the spider type) and just use a coax relay or maybe even parallel the feedlines.
Another option would be to build a 20m Moxon on a boom and then build a 10m yagi on the same boom... you could probably use "open sleeve" coupling (where you just put the 10m driven element really close to the 20m one)  and just build a driver-reflector type 10m yagi on the 20m Moxon's boom.
Dan
Dan
http://www.n3ox.net
KE4DRN
« Reply #10 on: September 14, 2009, 07:25:09 PM »
hi,
www.cebik.com has several articles on
stacking or nesting the Moxon,
some mulitband designs as well.
have fun with the Moxon !
73 james
