Author Topic: Heath AT-1  (Read 1278 times)
AB2MA
« on: February 21, 2008, 10:12:22 AM »
I'm restoring a Heath AT-1 and while disassembling I noticed that the ceramic insulators on the output and driver condensers were broken.These were made by the Cardwell Condenser Co.The Heath # is 26-21 and they are 50uuf.Any ideas where to get direct replacements?Thanks Stan
K8AC
« Reply #1 on: February 21, 2008, 01:00:59 PM »
Well, you might try Cardwell.  They're still in business and may well have an exact replacement.  You can also glue the ceramic if it isn't in a lot of pieces.  I've also used scrap Teflon material that I found at a hamfest to make replacement insulators for caps.  Target and a few other stores of that ilk sell plastic cutting boards that can also be cut up for such use.
73, K8AC
