If you are going to use the matchbox all of the time,
simply bypass the relay. This is easily done by
performing the following steps.
1. Remove the wire between the "input" SO-239 and
the relay.
2. Remove L1's wire from the relay.
3. Connect L1's wire you just removed in step 2
and connect it to the "input" SO-239. Do not
disconnect or mess with L1's ground connection.
4. Relay is now bypassed.
If you must use extra wire to accomplish the bypass,
make sure the wire is the same size and is solid,
not stranded.
An SWR meter placed between the transmitter and
the matchbox is required unless you're using the
Johnson Directional Coupler (SWR meter).
If you don't have the manual for the Matchbox you
can download it at the following website.
http://bama.edebris.com/manuals/johnson/matchbox/Click on the the matchbox.pdf link.
Mike
W5RKL
